Help me to work after Carbon Clean Please
08.05.2020 18:03 # 1
ginesis80
Hello friends pejo 307 1.6 hdi after my car maintenance (all filters have changed oil) .carbon clean everything is so gzl here. But when the starter presses in the morning, it works for 3-4 seconds, kicks and stops. I can operate it after pumping by hand on the air filter.
There is nothing in the waiting hours of 3-5 hours during the day, but when you park in the evening and run in the morning
I would appreciate if anyone has information and shares it.
ginesis80 2013-11-05 20:33:13
08.05.2020 18:03 # 2
Serkan
Sir, I think there may be a problem with the diesel filter.
08.05.2020 18:03 # 3
ginesis80
Thanks for the CVP, I wish it would be clogged if I changed the filters after carbon. I had a brand new inka brand I guess
08.05.2020 18:03 # 4
Serkan
Sir, I could not find the subject now, but the same problem happened in a friend after replacing the diesel filter, the filter was problematic and he changed the filter from the warranty and solved the problem. Make sure you always use original filters, which are likely to be from the filter.
08.05.2020 18:03 # 5
ginesis80
As you said before, I will share the result that I want to change from where I bought the diesel filter and thank you.
08.05.2020 18:03 # 6
ginesis80
Yes, the problem has been a problem despite my new appreciation of the diesel filter. Delphi brand, a new room was installed, no problem for 3 days. I think my mistake might be to have carbon clean after installing new filters. thanks serkan bey
08.05.2020 18:03 # 7
Serkan
Thank you, Hodja, thank you for sharing the solution.
08.05.2020 18:03 # 8
Alicilik
What is the relation of carbon clean with the filter?
08.05.2020 18:03 # 9
ginesis80
Honorable friend
Firstly, I used to have my vehicle 128 thousand, but first carbon, then change your filters oil.
relaxation is evident in the vehicle. gas reactions are improving. I was expecting that there was no smoke, frankly, I already used the cycle for 1-2 days and tried to dispose of the institution.
In a process that lasts for 30 minutes, they give the drug from the fuel pipes and it is cleaned with it, it says carbon clean. It was also in the bottle. The fee was 80tlidi in my care, I gave a total of 250tl.
-I have been using the vehicle for 1 year and I had it done in the 2nd maintenance to make my head comfortable.
-If you do it, if you do it in a professional place where you are conscious, you will harm it.
-If you need to pay attention to the first carbon then change the oil filters. (limited to experience) or you can suffer from my trouble.
I hope it helped
08.05.2020 18:03 # 10
Alicilik
[QUOTE = onurazgin] [QUOTE = Appealing] What is the relation between carbon clean and filter?
Immediately in the fuel filter, a liquid like water accumulates after carbon clean, the room prevents the vehicle from working. Some vehicles give anti polution fault error.
Thank you for answering the questions I asked .. [/ QUOTE]
It originated from the substance added to this fuel at that time. Some places are thrown from the injectors in order not to damage the fuel system.
