help me =) timing belt
08.05.2020 17:45 # 1
wlkn87
Hello, my friends said that when I bought a 2000 model 206 timing belt, I changed it, but frankly, I can not trust it very much because I have no experience in the car. how can i tell if i need to change it and what is the cost estimation thank you for your help in advance i apologize for the mods if i opened the wrong topic.
08.05.2020 17:45 # 2
umut_25
How many thousand km of vehicle
08.05.2020 17:45 # 3
wlkn87
134000 when I bought 124000 when I bought it, I changed the oil when the bidet was 134000
08.05.2020 17:45 # 4
samet206
It is hard to understand that a mechanic does not say that it is already open and it is not solid, but if you insert it and look at the cover from the outside, if its writings are not erased, you can verify that there is no wear and tear, but if you have any doubt, you will not lose anything, if you have any doubt, then you will not lose time. . Member
08.05.2020 17:45 # 5
wlkn87
What is the estimated cost? Bid this sound disease gerck mii
E
08.05.2020 17:45 # 6
tlp
Being 250-300 lira from 1500-2000 TL and go and change it.
I guessed it from God, I left the timing break so I saved the car with 1200 TL. they are going to go to work as a chronic malfunction, I think they will earn money for their masters. -07-02 19:16:59
08.05.2020 17:45 # 7
Serkan
Do not trust the writings on it, I changed it last week, its articles were still not deleted, it costs around 250 TL, if you can reach the old owner, do not risk your bill or change it.
08.05.2020 17:45 # 8
wlkn87
Thank you very much for all of your interest and interest, I will change this week.
08.05.2020 17:45 # 9
tlp
It would be better to replace it in the service instead of the industry.
Or, a strong, competent biker I know.
Because there is a sentence event (in the timers). I don't know the possibility of seeing, but the timing belt is in a closed chamber to the left of the engine.
08.05.2020 17:45 # 10
wlkn87
If you say service, I got the service, by the way, istanbul zeytnburnundym
08.05.2020 17:45 # 11
Serkan
If you go to the service, you may see prices such as 800 TL.
08.05.2020 17:45 # 12
pt206
1.5 years ago, I had changed it in the service and had kept 600 liras.
08.05.2020 17:45 # 13
tlp
Unfortunately, the service is expensive.
Didn't X go to a master? Doesn't he have a backing? After making tea soup until you do, who is the situation?
08.05.2020 17:45 # 14
hLL
The price I received from a private service. This is the mail they care about. I asked 2 weeks ago.
  timing set can be 90 TL original workmanship 60 TL and circulation can be 80 TL according to the situation.
< edited> hLL 2013-07-02 22:41:20
08.05.2020 17:45 # 15
wlkn87
There is a mechanic I have been going to for the change of lining and vss so far. It sounded harsh or it doesn't come when I took the car, the man pulled a strap from the trunk, the timing belt has changed, he said 50 lira flan but he got stuck in my head now: S
08.05.2020 17:45 # 16
error
valla heavy maintenance (timing pads etc.) for the authorized services, yes it is salty but it guarantees the work done after the operation, now you know what kind of expenses a special service can open in the long term in the belt ...
< / div>
gaziosmanpaşa there are baybans, i went there last but the masters are not bad, but if you say special, paris peugeot let alone the master is meticulous man ...
errör 2013-07-02 23:16:01
08.05.2020 17:45 # 17
wlkn87
[QUOTE = errör] I mean, it is salty for me to have heavy maintenance (trigger press brake etc.) done by authorized services, yes it is salty but after the operation, it is a guarantee of the work done, now you know what kind of costs a special service can open up the belt and adjust its tension ...
gaziosmanpasa there are baybans last i went there its masters are not bad
Do you know the price, master
08.05.2020 17:45 # 18
error
no wlkn it has been two years, i had to change it, then i had it changed in bosch service due to financial matters but since then if you have the opportunity to squeak in 1st gear in the parking lot, do not change the belt as a bosch service or special service. Replace the circulation pump ...
You can get a price by phone from Baykara ..
08.05.2020 17:45 # 19
Mustafa-almanya
[QUOTE = wlkn87] There is a mechanic I have been going to for the change of lining vss so far. So when it was loaded on the gas, the light belt sounded stiff, or it doesn't come when I took the car, the man pulled a strap from the trunk, the timing belt changed already, he said 50 lira flan but he got stuck in my head now: S [/ QUOTE]
1. A friend of mine told me that the car had burned before the timing belt change. After the belt changed, the car started to burn less. (Car: Ford Escort Diesel)
2. In 99 years, I had two golf cars, and when I was on the highway, I heard a sound like the engine was turning from the engine. Trigger apricot was broken. It was understood from the sound of the engine when it ages / needs to change according to the service. I am concerned with my car, but I did not notice anything. They came up with a more expensive repair list than the running value of the car, so I threw it in the car spit (Car VW Golf 2 gasoline 60 horsepower)
3. At one time BMW 318 min (94 Model), I think it was 160000 Km, I had the timing belt change. I did not feel neither a fuel difference nor a sound difference. I changed it because it was kilometers.
I don't know if the symptoms differ from brand to brand.
I am now looking at the service book, I am careful not to change the mileage I will drive. The most acceptable thing is that it has changed recently or at least 50000 Km change is not required (This is my view). If the change was made in the service, when the bonnet is opened, a note can be written indicating the mileage it changes just above the louver. (95 model Audi A4 was written and attached to a metal plate).
The timing belt is imperfect. That's right, I had the right Opel vectra gts. 2004 model. His engine was in chains, as far as I know, there was no change. It had to be checked at 250000 km.
We hope you find useful information ....
Respects
08.05.2020 17:45 # 20
wlkn87
Today, I called the berke service b.In the village, the price of 1200 TL: S industry road appeared, apparently called me the timing belt from the timing belt vss. He said the price will be 1200 TL.
Page : / 2
