help me how to assemble the repair kit !!!
08.05.2020 15:24 # 1
ose
My problem is that it does not matter whether it is on or off, it makes a squeaking sound on the way. I bought the repair kit in the picture, and if I can remove the glass, I will be able to install it. I changed the front legs, I have to put the plastic on the other four legs
sanruf repair kit. I put the pieces on the big left I couldn't put the others on
my money
sanfuf from different angles
kankam_743 2011-05-17 00:15:51
08.05.2020 15:24 # 2
eren8er
which picture?
08.05.2020 15:24 # 3
flash296
bro you do not need to disassemble ... I had the same problem, I applied gress oil on the sled roads, there was no sound left .. if you try you will get a good result ....
08.05.2020 15:24 # 4
flash296
Drive to all the moving areas and the roads of the sunroof, brother!
08.05.2020 15:24 # 5
yusuf206
I can help those who have problems with the sunroof engine ......
08.05.2020 15:24 # 6
ose
[QUOTE = flash296] all the moving regions and drive on the roads of the sunroof bro! [/ QUOTE]
Unfortunately, there is not a solution, I have a lot of space, and the four tires on the feet seem to be gone. I bought those parts original 35TL without French.
kankam_743 2011-05-20 19:54:19
08.05.2020 15:24 # 7
ose
Does anyone know how glass is removed?
08.05.2020 15:24 # 8
ose
Where are the coliva, cerci and other experts? help
08.05.2020 15:24 # 9
cerci07
I don't know how bro is inserted in my car because I don't have sanrof, but I can help
By mustafacerci at 2011-05-17
French is not very good and it becomes incomprehensible when it comes to technical terms in the business. Even its native language does not understand technical terms.
insert plastic caps, if any.
insert the antenna
put the curtain in place
Put the locks to stop the mosque somewhere like on the first picture.
open the mosque with the help of hand
Insert the screws in the picture number 3 (I think the mosque remains inside after opening)
4 says inside then loosen these screws 5 on the right and 5 on the left
after that two people say go ahead
5 as in this picture, there are fingernails that hold the front of the glass slightly, I guess, remove them, and close the mosque by hand, ten parts raised.
Turn the mosque slightly to the left 10 cm before it closes and remove the left back fingernail. After the left side is removed, bring the mosque back to its normal state and remove the nail of the right side.
I understand it so much when I can tell you so much and I have neither seen or sanrof before, if you say I do not want you to do something wrong in my security, Exclamation
If you can, you can collect it as you can
08.05.2020 15:24 # 10
ose
You are super. I understood most of them with your expression, the image is not clear. Did you download this book or from the net? Can you send it to my mail address kankam_743@hotmail.com ? or where can I find it? kankam_743 2011-05-18 01:28:36
08.05.2020 15:24 # 11
ose
[QUOTE = cerci07]
5 as in this picture, I think there are fingernails that hold the glass on the top of the glass slightly, remove them ten parts [/ QUOTE]
5 right 5 left (4 right 4sol, 12 screws in total) only I don't have those screws: (((all others fit or does your floor remain gold?
08.05.2020 15:24 # 12
cerci07
[QUOTE = kankam_743] [QUOTE = cerci07]
5 right 5 left (4 right 4sol with 12 screws in total) only I don't have those screws: (((all others fit or does your floor remain gold? [/ QUOTE]
I guess you should be under the floor
Göz Kırpma
08.05.2020 15:24 # 13
ose
I also developed a strategy to remove the flooring research okay don't worry Thumbs Up
I have a chance to care for both gears.
the only thing missing is the garage garage garage. It does not become an open air.
kankam_743 2011-05-18 23:53:44
08.05.2020 15:24 # 14
Kemanyak
Open the sunroof to the end
Then remove the screws 3
Gently push the sunroof forward (the curtain will remain open)
There is a space in the sleds where the front legs can come out while pushing the glass forward
Take the front two legs out of that space
Then the back feet are slowly and very carefully removed.
Be very careful when replacing the glass, you will have to squeeze a little.
Come easy, I used plastic called crickets because I couldn't find a repair kit for the feet Clown Can you tell me where you supplied the parts? I do an operation for him this summer Sırıtma
08.05.2020 15:24 # 15
ose
[QUOTE = Violinac] Open the Sunroof to the end
thank you. I bought from the authorized service, the repair kit is passing the price of 35TL. they want 150tl of workmanship to wear in the service bloodless. I will look at the code and throw it to you
kankam_743 2011-05-20 03:21:43
