Help Masters .. 2002 model XR transmission malfunction .. |
| 08.05.2020 21:20 | # 1 |
| 08.05.2020 21:20 | # 2 |
I recommend you to change the gearbox oil. If it is time to change the engine oil, let's change it. |
| 08.05.2020 21:20 | # 3 |
The rpm increases because the transmission cannot provide enough pressure. The gearbox, which senses this, protects the brain. There are two possibilities. In the first case, you can only recover with gearbox oil change. The second possibility is the transmission oil change again with the solenoid change. You can check the pressure values by connecting to the computer whether solenoid valves are working or not. Or it does not give definitive diagnosis, but start the vehicle, open the window, change the gears to r and d. When you are at d and r, check if you hear any sound like bee buzz. If sound is heard, solenoid valves are intact. The process of protection will gradually increase over time. My advice is not to start without heating. Once protected, stop and run again.
| 08.05.2020 21:20 | # 4 |
[QUOTE = talip206] The rpm is increasing because the transmission cannot provide enough pressure. The gearbox, which senses this, protects the brain. There are two possibilities. In the first case, you can only recover with gearbox oil change. The second possibility is the transmission oil change again with the solenoid change. You can check the pressure values by connecting to the computer whether solenoid valves are working or not. Or it does not give definitive diagnosis, but start the vehicle, open the window, change the gears to r and d. When you are at d and r, check if you hear any sound like bee buzz. If sound is heard, solenoid valves are intact. The process of protection will gradually increase over time. My advice is not to start without heating. Once protected, stop and run again. [/ QUOTE] I changed the gearbox oil, the problem was not solved, and when I connect it to the computer, no error code appears and the pressure values seem normal. I didn't understand anything from this.
| 08.05.2020 21:20 | # 5 |
[QUOTE = pusutr] I suggest you change the gearbox oil. If it is time to change the engine oil, let's change it. [/ QUOTE] I changed all of them, teacher, I did not get any results ..
| 08.05.2020 21:20 | # 6 |
sonerkyl |
Replace the brake sensor in one can cause malfunctions even if it does not fail.
| 08.05.2020 21:20 | # 7 |
[QUOTE = sonerkyl] Replace the brake sensor in one can cause this type of trouble even if it does not fail. [/ QUOTE] Hmmm okay, teacher, keep in mind, thank you.
