help it burns a lot |
| 08.05.2020 14:56 | # 1 |
I have a car, it burns 0.40 cents despite the change of the air filter even though I don't use delicate what do i have to do to burn less
| 08.05.2020 14:56 | # 2 |
bro, if you can write the details of the vehicle, let's try to help if you tell me the contents of diesel diesel
| 08.05.2020 14:56 | # 3 |
immediate typing 1.4 xr 2001 model pejo 206
| 08.05.2020 14:56 | # 4 |
No matter what my brother, the car shouldn't burn that much ... I say change the gas filter |
| 08.05.2020 14:56 | # 6 |
When I say it burns, I would come with a fire extinguisher
| 08.05.2020 14:56 | # 7 |
What is the mileage of the vehicle first? Did you get your car new? how is the vehicle pulled? you changed the air filter but not enough. the spark plugs should change the oil and the oil filter of the engine. bobbin, tires and air, throttle, map sensor, injectors, oxygen sensor and catalytic converter should be checked ... there are many things that will affect the fuel in general ... |
| 08.05.2020 14:56 | # 8 |
I bought my arc just 115 kilometers, the first gear of the vehicle is nice, but the 2-speed titriyo on the hill
| 08.05.2020 14:56 | # 9 |
don't come bro!
| 08.05.2020 14:56 | # 10 |
oguzhan29 |
Show a service, did you care or something? What is the condition of the vehicle?
| 08.05.2020 14:56 | # 11 |
the clutch is flinging |
| 08.05.2020 14:56 | # 12 |
how the clutch misses brother or how
| 08.05.2020 14:56 | # 13 |
If the engine is overturned when full throttle is pressed, the speed of the vehicle does not increase at the same rate, the entire revolution produced cannot be transferred to the wheel. In addition, if the vehicle does not skid, it can be understood that it is peeling off or low on the high face.
| 08.05.2020 14:56 | # 14 |
If you change the solution, it costs 500 lira in a diesel, I think it costs a lot, but this is a little more in gasoline, but clutch fuel will have a lot of effects.
| 08.05.2020 14:56 | # 15 |
yes, it might be finished, and gearbox seal clutch may be lubricating
| 08.05.2020 14:56 | # 16 |
is it only understandable without shaking when going uphill in 2nd gear, and sometimes it comes in the smell as it stretches out from the clutch but it pulls paw or something
