help indash usb connect
08.05.2020 14:01 # 1
EMRE
There was 106 indash dvd, we couldn't connect any type of usb to the alpine, the systemer said to buy a cable and went to the wiring and did not have a suitable cable. Big 20smil% to they say it happens but we couldn't do that is it hard is my cable has the wrong setting
on the cable this
http://img165.imageshack.us/img165/6561/13012009re3.jpg
08.05.2020 14:01 # 2
hasimayaz
I did not understand what the cable is in your hand, one side is mini stereo one side, usb female .. Connect the USB pin outs of your indash by using the panel in the picture ??
P Signal Color Description
one VCC
+ 5V
2nd D-
Data -
3 D +
Data +
4 GND
Ground
08.05.2020 14:01 # 3
EMRE
hasim has 2 wires on the back, one of them is yellow as the ipod outlet, the place where the white red ends in the picture will be attached, the bidet is the place to hang on the end of the red and white ends in the picture
http://img510.imageshack.us/img510/4460/13012009001ii1.jpg
08.05.2020 14:01 # 4
hasimayaz
All right, you have attached a tip that converts two tulip sockets into mini stereo. These are just socket types used for audio and video signals.
Can you send photos of the entries on the device (with the text visible)
08.05.2020 14:01 # 5
EMRE
I will send tomorrow photos
08.05.2020 14:01 # 6
elenor
[QUOTE = emquazarre] hasim has 2 wires on the back of it, one as ipod out, in the form of a place where the white red ends in the picture will be attached, a bidet in the shape of the end of the red and white ends in the picture
the cable in the picture is the one side usb [yellow-white ends] stereo jack, which is also called as dust jack on the other side, to connect with this cable, you should have dust jack audio connection inputs on the back side of the tape, I think you need the stereo multiplexer at the end of the dust jacks through the ipod, I guess you need full
08.05.2020 14:01 # 7
EMRE
I want to connect a memory, not an ipod. I have the ipod input behind it, I learned that the converter can be connected and memory can be connected.
