help head I'm about to eat
08.05.2020 18:55 # 1
samu
Hi friends, I have a 2011 model gasoline 308, the car runs jerky, I don't give gas, it doesn't work like a water engine, it explodes like a water engine, the fan is running right away. it was indelible, the lamp burned again, I did not care, I rode it, then it went out spontaneously. almost brother, help me
08.05.2020 18:55 # 2
tolga.onal
Probably it is made of ignition coil, it does not eat gas, it makes extreme jolt, the car will not walk, if you force it, but it will go as if the engine will break, I lived this moment .. But you said I changed the coils.
08.05.2020 18:55 # 3
muro_60
Is he always doing cold?
08.05.2020 18:55 # 4
millesim
may be from the ignition system .....
08.05.2020 18:55 # 5
samu
4 coils have changed, it has not been 1 month yet, when it first started the engine was not working, it was like this, I started this morning, no shaking, but the malfunction lamp is on, I take it to the master. I asked 425, if he is not there, we will go to our money again
08.05.2020 18:55 # 6
tolga.onal
The coil is not 4 pieces, it is a spark plug. There is an ignition coil. When you open the hood, it is immediately on top when you remove the cover that the engine is. Try it around 150 pounds.
08.05.2020 18:55 # 7
samu
We know how the spark plugs are, I know how :) I changed them too. These coils longer than those on the spark plugs head have changed in the special service. It is written on the invoice, I already gave 90 lira to the number
08.05.2020 18:55 # 8
koray.turan
Sir, there was a problem with my injectors or cables. As you said, the water engine is like a tractor, the sound choke is out of the vehicle
08.05.2020 18:55 # 9
sebar
You've spent money and time in vain. The problem is in LPG. As far as I understand from what you wrote, the vehicle is lpg li. I have 2010 too. When there was no problem with gasoline, my master insistently said (I will make an economy). The same problems started in me. Unfortunately, this problem happens if you want to move immediately when the engine is cold or when you turn the first contact after long periods of wait. Operate at idle for at least 1 minute without moving the vehicle. then it does not happen. French group vehicles are not compatible with LPG. My uncle also has citreön c4 and the room suffers from the same issue. previously there were 406. I got a lpg 6-7 months later, he started to stop on the way. Imagine that you are driving at a speed of 100 km and the vehicle stops. everything is getting locked. The point that lpg companies will do is this; These types of vehicles are not compatible with LPG and they will say to our brands. Our vehicles are not compatible with LPG. Of course, when commercial interests come into play, no one is making a noise. happening to the citizen.
08.05.2020 18:55 # 10
10URAKAR
Hi ,
Sir, I think the detonation of the vehicle is due to LPG.
If you have a problem with the coil, you can test it yourself ... (Open the bonnet and test as if your car is giving gas to the throttle attached to the engine, press it suddenly. is broken.)
The other point is that the cooling fan is running right away ... it seems interesting to me that it seems like there is a problem in the water circulation of the LPG system and the vehicle, if it does not get the required efficiency, the vehicle started the fan directly.
In the meantime, it is a must to heat the LPG vehicles at the first start, and I have the PU 206 where I stopped to switch to gas ...
In cold weather, cold friends machines are inevitably shaken.
08.05.2020 18:55 # 11
gungor
have you changed the timing
If it has changed, it may have jumped to the sent vehicle, the vehicle that jumped to the synthesis will not consume gas, so it gives a mixture failure.
