help getting water from sunroof
08.05.2020 17:12 # 1
deme
friends, there is no peugeot service here. I went to a normal body shop, said sunrof water inside, said my teacher, we will look at the ceiling will be removed, he asked for a price of 300 TL. I'm waiting for your car 307 help. There are drain holes in the front of the coin, I pour water on them, they work well, they are not clogged. I wonder if there are drain holes in the back. When I open the sunrofu, I cannot see the drain holes on the back. I wonder how I can control them. thank you for your help
08.05.2020 17:12 # 2
deme
need help as it will rain "Cry"
08.05.2020 17:12 # 3
hsnsnl
there are holes in the back and there are holes in the back ..
08.05.2020 17:12 # 4
deme
i have a curiosity & nbsp; Previously, there was a malfunction of 400 TL. I wanted to solve it at zero cost thanks to the service forum. how to disassemble it, if any, or pictures
08.05.2020 17:12 # 5
hsnsnl
when you pull the front poles from the dislocated places immediately. then you have to take the front lamp out of the ground, insert the glass and have the nails on the back, if you press it with the gozukuyo tornado, you have to pull the cable in your hand .. you have a screw on it right away, you put it in it, you think it is in the part .. you have to insert the cable in it .. lastly there are 2 plastic screws on the back side. They have too much pressure on them. >
08.05.2020 17:12 # 6
sansasyon61
There was a problem with me a200 TL I loved the sunroof, the piece cracked, the water is running out, the piece is small, after that, there is no problem.
08.05.2020 17:12 # 7
deme
as I understood my problem more or less. the water passes into the interior of the spring, where it is drawn, and from there it escapes through the hole through which the twisted wire passes. & nbsp; but I do not understand how it goes.
08.05.2020 17:12 # 8
hsnsnl
you can see the sunroof discharge pipes after the ceiling is dumped, you can adjust it from the places that come out one by one and you can set it according to the situation. you need to insert the glass .. if you do it by inserting the sunroof mechanism, it will be the number 10 :) After you have 12 screws, you put the cable on the duser engine and you can clean the mechanism ...
08.05.2020 17:12 # 9
deme
If I knew how to remove the glass of money
08.05.2020 17:12 # 10
hsnsnl
sunroof u hat like air lift it stay in the 3rd level keeps it in 4 screws already you can insert them, you can remove the glass
08.05.2020 17:12 # 11
deme
I poured water with funnel to the drain holes. I closed the sanher and poured water with a bucket, then I opened the sanger. The broadcast shot is on the inside, but I do not understand where it is passing. There is a twisted black wire on both sides of the water passing inside. puts water into the floor through the hole where the wire enters
08.05.2020 17:12 # 12
deme
drain holes work well. front on
08.05.2020 17:12 # 13
hsnsnl
I think you need to clean your waterways and check the drain pipes etc .. from the ground and the easiest from the ground to the inside.
08.05.2020 17:12 # 14
deme
after pouring water & nbsp; Then I lifted the back of money and looked. it was dry so the back part was very & nbsp; water does not escape
08.05.2020 17:12 # 15
yusuf 406
nylon ser for a while I do not do it yourself, then the cost is much more, I wanted to sit down in the place where I could not wash the headlight was broken, something was broken like a pen, if I made 350 TL, 50 TL or more, if you break the engine, I do not remember the wrongness of the money, if you break the engine, then I will remember the wrong value of 800 TL.
08.05.2020 17:12 # 16
deme
Thanks to my friend hsnsnl, thanks to him we downloaded the ceiling tile today. I hope we found the leak, we can do it. friends went to dinner tonight we'll try
08.05.2020 17:12 # 17
deme
He was kidnapping the two front corners of the sunraof.
08.05.2020 17:12 # 18
deme
I saved my vehicle from getting water. thanks to the forum
08.05.2020 17:12 # 19
swing67
So, my brother, I revived the issue. I think I am having the same problem with leakage. How did you cut the water leaking from sanrof corsets & nbsp; down here.
