help friends closing the car with tarpaulin
08.05.2020 14:58 # 1
Eleanor_
Hello friends, if you have a little question, I will go to military service in the range and I want to put my car in the open parking lot of the workplace and cover it with a tarpaulin.
First of all, I want to cover the sunroof part nicely with nylon and cover it with canvas, but will the tarpaulins damage the vehicle? Does it cause a problem in paint? when capillary scratches are not a problem, it will be fixed with a cake, but I would like to ask for a worse situation and get water.
08.05.2020 14:58 # 2
No, dude, the tarpaulin will do nothing, if you have a parking lot on your head, do it with your peace of mind.
08.05.2020 14:58 # 3
I use my car very often in the parking garage.
08.05.2020 14:58 # 4
Eleanor_
thanks friends, I had some hesitation for your comments
08.05.2020 14:58 # 5
selfat8
friends under the roof, on the ceiling, on the hood, on the trunk, these are the cleaning sponges 6. Put 7 pieces of tarpaulin to stick to the paint completely, wrap it beautifully, nothing will happen for a closed parking lot.
08.05.2020 14:58 # 6
I do not think there will be a problem, but as the friend says, the canvas can be stuck when it is in contact with the vehicle for a long time.
08.05.2020 14:58 # 7
Eleanor_
thanks guys, the car will stay in the open car park, though it doesn't sweat because it will stop in the winter, but as I said, it still sticks to the mind, it goes with a cake but it doesn't matter if there are permanent stains.
08.05.2020 14:58 # 8
tugrabozan
Unless the temperature drops below zero, bro. It's bad if it freezes but
08.05.2020 14:58 # 9
Kifanhom
You said parking lot
if the sun is going to take off in summer, there is a high probability of sunburn in the paint of the vehicle.
08.05.2020 14:58 # 10
selfat8
You asked for the solution, we offered the solution under the canvas, the temperature and humidity would be 2 times more than the outdoor temperature. The canvas sticks to the vehicle.
08.05.2020 14:58 # 11
OZC@N
WIND WIND AND CANNOT BE MOUNTED IN THE BRAND, THROUGH THE PAINT OF PAINTING WILL REMOVE BY EXPIRING ... CAN BE DRIED FROM THE BRAND. Embarrassed ... MEET YOUR SAY AND LEAVE WHAT ME
08.05.2020 14:58 # 12
frk_206
depending on the material from which the branch is made
my father's nissan primera vehicle stopped with tarpaulin outside for 1 year (winter and summer) when we opened the leaf at the end of summer, there was sunburnt in the paint and the face of the paint was roughened when you rub your hand when you rub your hand. SırıtmaSırıtma
The tarpaulin we used was one of the blue tarpaulins used by truckers: D
08.05.2020 14:58 # 13
If it were me, I would give a little money and put it in a closed car park and not cover the tarpaulin.
If it was trusted, I would give the key to the owner of the parking lot and occasionally work and run two laps. Koliva 2010-11-26 14:27:38
08.05.2020 14:58 # 14
ali oncu
I did not like this tarpaulin event, it has rain, I think it is more permanent and solid, you should go to r method but of course the decision is yours
