HELP FRIENDS
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » Old Models
08.05.2020 17:14 # 1
leony510
hello friends new tire on my vehicle was installed. I am currently using the 205-45-16 Alessio wheel set. Do you think the vehicle should wear 3.5 or 5 sports springs? When you get on 5 people, how would you recommend the best one without rubbing comfortably and healthily? Also I am waiting for help from masters who use the bow which is more comfortable .. I request urgent help, regards .. "2049" border = "0" />
08.05.2020 17:14 # 2
hsnsnl
according to the road conditions 3.5cm.
08.05.2020 17:14 # 3
leony510
5 is it too low?
08.05.2020 17:14 # 4
Alicilik
There is no noticeable difference in 3.5cm. 5cm is a must if you say something.
Unless you rub the back, you won't experience much. I have 175/65/14 tires in my car and the spring brush is 5 people in the original car, I can not even think of the spring rubbing in the stretches. Reviews
08.05.2020 17:14 # 5
Alicilik
I also caught my attention in terms of photography or the wheels off the inner offset. How many ET values do you know?
08.05.2020 17:14 # 6
Alicilik
[QUOTE = 307 bursa] 205 * 45 * 16 is outside the original size so I know the rims look out of the way & nbsp;
if you put 5 glass springs in this state, it seems to me that it is rubbing 3.5 does not matter, it does not matter, only comfort is going ok & nbsp;
no bro, well the base is wide. As a result of the base, the rim does not stand out, probably the ET of the rim shows this. Reviews
08.05.2020 17:14 # 7
leony510
In short, I want the image to be this, & nbsp;
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-jant-lastik-jant-lastik headsets for-205-45-16-alessio-wheel-tire-4-month-109 123 730 / details /
08.05.2020 17:14 # 8
leony510
I do not want to rub your friends, I expect your expert masters to be guided
