Help for the sake of Allah is a strange problem
08.05.2020 19:37 # 1
emre_65
First of all, friends are solid and newly coded problem, I open the doors, the fault lights are on, the indicator lights up after turning on the ignition, it turns off, I turn on the headlight without installing the contact again, the fault lights are on again, I press the door lock button from the inside again. stop light with gasoline light flashing vehicle 2002 1.6 xt petrol LPG wonder what's wrong
08.05.2020 19:37 # 2
hsnsnl
They did not connect the vehicle in accessory mode.
08.05.2020 19:37 # 3
hsnsnl
They did not connect the vehicle in the accessory mode.
08.05.2020 19:37 # 4
emre_65
What do you call accessory mode, do you open a little bit and you called connection bsi sockets?
