Help for print pads |
| 08.05.2020 17:55 | # 1 |
Thomassee |
Hello friends. Unfortunately, my 206's press pad is now deceased. I was barely close to home, I could barely come. I was able to take a master here soon, he said to me between 450-500 materials + workmanship. How do you think this price seems a little expensive to me? Is there a place you recommend ?? Thanks. |
| 08.05.2020 17:55 | # 2 |
Clutch is good for the price.
| 08.05.2020 17:55 | # 3 |
Thomassee |
[QUOTE = baroff] Clutch is good for price. [/ QUOTE] I forgot to write yes clutch. |
| 08.05.2020 17:55 | # 4 |
change it to set, just make sure if the master changes the lining just because I will do it cheaply.
| 08.05.2020 17:55 | # 5 |
I had it built for 900, including labor, at the authorized service. but it was worth it, the driving comfort had increased officially ...
| 08.05.2020 17:55 | # 6 |
Thomassee |
[QUOTE = ahmetismet] I had it made to 900, including labor, at the authorized service. but it was worth it officially improved driving comfort of the car ... [/ QUOTE] I'm expecting a similar effect |
| 08.05.2020 17:55 | # 7 |
gogly35 |
Hello, first of all let me say .. I have not encountered such a problem before, thank goodness, but something is stuck in my mind. But I don't feel any malfunction in the gears, I just feel from the pedal.
| 08.05.2020 17:55 | # 8 |
Thomassee |
[QUOTE = gogly35] Hello first, let me say that it is past. I haven't encountered such a problem before, thank god, but something gets stuck in my mind. But I don't feel any malfunction in the gears, I just feel from the pedal .. [/ QUOTE] It may be the same problem as mine. The eclipse also happened to me. Even though it does not come back to the pressure, it seems like it is barely attached. I just came under the clutch and pulled until I brought it home |
| 08.05.2020 17:55 | # 9 |
gogly35 |
Come on, you scared me now :)
| 08.05.2020 17:55 | # 10 |
I do not know if your vehicle is diesel, but I am talking for gasoline expensive teacher 200 TL parts 150 Workmanship 350 is all I have passed with the master, 50 TL catering, I always go there 300 I made last month Parts and labor cost 350 TL, if your vehicle is 1.4 gasoline, your master shook 500 bads apart from these If it is a model, I can say the price is affordable :) |
| 08.05.2020 17:55 | # 11 |
Thomassee |
[QUOTE = samet206] I do not know if your vehicle is diesel but I am talking for gasoline expensive teacher 200 TL piece 150 Labor 350 is all I have passed with the master, I have 50 TL catering, I always go there 300 I made it last month Part and labor cost 350 TL if your vehicle is 1.4 gasoline, your master If it is a model that shook 500 badly, I can say the price is affordable :) [/ QUOTE] Diesel teacher. Transmission oil or something will change. Thank God he hasn't had a problem so far. If you were a familiar master, it would be a treat, as you said, but unfortunately there is none. I will also ask the authorized service tomorrow, but I think they do it very expensive I wish these services would keep their prices a bit affordable. |
| 08.05.2020 17:55 | # 12 |
If the clutch is not attached and it does not come back, friends have a clutch wire 50 lira :) it happened to me. Then I took the wire to the master officially scrap. Imagine the way of telling the bicycle brake wire so that you can have a visual bite in mind. |
| 08.05.2020 17:55 | # 13 |
gogly35 |
I have a clutch wire record, I pressed for back maneuvering in our letterpress vehicle, and the last press was the pedal was left inside, then the industry ways with the car: D
