|   | help for multimedia navi system please :) |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 17:37 | # 1 |
|  deelly | |
| 08.05.2020 17:37 | # 2 |
|  Alicilik | |
Sir, there are systems for 307 in big companies with Pioneer banners or sign in Ankara. There are two types.  There are direct 7 "double din format tape mounted on the middle panel and the systems where you remove and install the CD changer underneath. There is also a special screen and tape separate system for the 307s. You disassemble and install the tape unit of your tape recorder. You disassemble the information screen in the middle and attach it there. Both of them are very close to each other and completely made of china. I do not want to say "China" and do not want to be bad because there are 10 different types of similar product. Things to consider in this kind of products. screen quality-processor frequency and ram memory-antenna quality-color matching with your vehicle. | |
| 08.05.2020 17:37 | # 3 |
|  qqyyxx | |
For old safes, I advise rt3 for the new safes. You can't see the trip computer parametrelwr on the torpedo in the old cases.
| 08.05.2020 17:37 | # 4 |
|  deelly | |
First of all, thank you for writing and lighting for a long time. Well, if I looked at a multimedia device with a second hand navigation, which model would you recommend? Which one would you recommend or do you know for sale? Meanwhile, my vehicle is without a make-up case, but cc model 307
| 08.05.2020 17:37 | # 5 |
|  qqyyxx | |
http://www.sahibinden.com/ilan/yedek-parca-aksesuar-donanim-tuning-ses-sistemleri-muzik-calar-oto-teyp-peugeot-307-oem-dvd-121510293/detay   you can look at this ad, it said to me 600 last but i did not want to buy it without seeing abu seller ankara. you can look. or you can overcome a d2 to the center console. The product in the ad is closer to the original, but.  | |
| 08.05.2020 17:37 | # 6 |
|  deelly | |
Yes, I talked to a friend, but my car 2005 model 307cc I think there will be incompatibility with my car.
| 08.05.2020 17:37 | # 7 |
|  alp2525 | |
http://forum.peugeotturkey.com/forum_posts.asp?tıd=23216&title=tamamen-kend%dd-yaptiim-307me-uygulamalar-%ddnceley%ddn  the prinha encore model, which I rained on my old vehicle, does not support zero tl handle, but I made and run its circuit myself.
