help for led
08.05.2020 18:19 # 1
ERDINC
I will connect a red strip led to the rear fenders, but when the parks are open, when the leds will be a little dim, the brakes will be stronger when the brakes are pressed ???
08.05.2020 18:19 # 2
Alicilik
[QUOTE = ERDİNÇ] I will connect a red stripe led to the rear fenders, but when the parks are open, how will the wiring be stronger when the leds will be a little dimmer when the brake presses ??? [/ QUOTE]
You will buy and connect from American parking modules, sir.
08.05.2020 18:19 # 3
ERDINC
No, I have not seen mine will be the first :)
08.05.2020 18:19 # 4
ERDINC
I wonder if I would connect it to normal stops, parks, remove the plus from the brake light and connect the led.
08.05.2020 18:19 # 5
Alicilik
[QUOTE = ERDİNÇ] I haven't seen mine, mine will be the first:) [/ QUOTE]
The system of the American park works on the principle you mentioned, teacher.
The current from the parks is reduced to 5 volts. Connecting to these signals. When you burn the signal, the mast comes in 12v and burns at its normal brightness. When you connect a low parking module, it will be as you requested.
08.05.2020 18:19 # 6
Alicilik
[QUOTE = ERDİNÇ] I wonder if I would connect to normal stops, parks, remove the plus from the brake light and connect to the plus of the led [/ QUOTE]
When you apply the brakes or open the parks
Brake lamp
-Park lamp
-The leds you connect are all lit together.
You either cause an accident in traffic or eat swearing. LOL
If you do not put a diode in between, the current passes through all the ways, and all connected bulbs light up.
08.05.2020 18:19 # 7
ERDINC
http://urun.gittigidiyor.com/otomobil-motor-aksesuar/amerikan-sinyal-park-modulu-kargo-bedava-101647041 I think this module will work for me, I will not connect to brake lights but not signals.
08.05.2020 18:19 # 8
Alicilik
[QUOTE = ERDİNÇ] http://urun.gittigidiyor.com/otomobil-motor-aksesuar/amerikan-sinyal-park-modulu-kargo-bedava-101647041 I think this module will work for me, I will be connected to brake lights rather than signals [/ QUOTE]
He sees, sees. I also use the same.
It has 3 cables,
blue
black
black red
scheme below
08.05.2020 18:19 # 9
ERDINC
Thank you very much, it would be very difficult to interpret and apply the schemes that will be useful for me.
