help for istepne
08.05.2020 15:14 # 1
yalazan
slm friends, i did not write the wrong place, my car is 2003 307 sw how it hurts i want it
08.05.2020 15:14 # 2
metin
I don't want to be like misleading, but I know that hachbacks are at the bottom of the trunk and sws are at the bottom of the trunk.
If it is outside, it must be something like a bolt in a barrier inside the trunk, as I turn it, I guess that the rope that holds the tire becomes empty and the tire goes down.
08.05.2020 15:14 # 3
yalazan
My brother, I am pouring that bolt. It does not come down. My hands are tired.
08.05.2020 15:14 # 4
Exactly Mr. As Metin says, there is a bolt in the plastic cover in the middle part of the trunk. I hope you can understand water more easily than the sky.
08.05.2020 15:14 # 5
metin
koliva I'm sick of your schema business ((:
08.05.2020 15:14 # 6
[QUOTE = yalazan] my brother, I am turning that bolt down, my hands are not tired, my hands are tired, he did not come down [/ QUOTE]
I think we couldn't explain it fully. I say so. There is a plastic that stays slightly to the left when the trunk moves. You can lift something like a ring inside. You have to lift it and shoot it. It can be pulled up about 4-5 centimeters. Tilt to right or left. When you turn, you will see a hex bolt underneath. You have to freeze it. If you have a hard time, I can take a picture of me right away.
08.05.2020 15:14 # 7
[QUOTE = text] koliva I'm sick of your schema job (: [/ QUOTE]
No matter how much we tell, it is not as beautiful as a painting. A picture is worth a thousand words Sırıtma
08.05.2020 15:14 # 8
Don't look at the picture, I uploaded it to another place. Here:
08.05.2020 15:14 # 9
yalazan
My brother finally got it in my hand I was going to freeze it when the plastic was pulled, it was left in my hand now, only 5 gen bolts remained. Confused
08.05.2020 15:14 # 10
yalazan
brothers, i need your help how to make this request, i pulled it in the shape of a ring, but the other 6 gen bolts will be freezing all the time.
08.05.2020 15:14 # 11
metin
Maybe it is peeling off when you turn it, hit the tire from the bottom a few times and it will be fixed.
08.05.2020 15:14 # 12
My brother, remove the tool, take a look at the bottom, but watch out!
