help for headlight adjustment
Homepage » PEUGEOT MODIFIED PLATFORM » How To
08.05.2020 18:45 # 1
zr`lmn
I have 3. My car and all of them have a headlight problem. I can not get the headlight because my material does not give. Headlight right left adjustment is done, left headlight height adjustment is OK but right headlight is slightly down. Right headlight adjusting motor malfunction. When I remove the cover on the back of the mouse, I can play the part of the mouse with the hand up and down (manually, or I don't know if this is supposed to happen). Will it cause any harm? I'm looking for a Turkish style solution
08.05.2020 18:45 # 2
zr`lmn
Can I do it with hot silicone?
08.05.2020 18:45 # 3
aokaymaz
If the inner part of the headlight makes up and down too much, the part like the knob at the end of the headlight engine may be dislodged. It is normal if it flexes slightly
08.05.2020 18:45 # 4
zr`lmn
It moves too much. The best master here! I got it when I said let's not let the headlight stay in my hand.
08.05.2020 18:45 # 5
suppor
Disassemble the master, remove the ten blinds first, then, on top, there are 3 bolts on the bottom, 3 bolts on the head, in the hands of the headlight :)
08.05.2020 18:45 # 6
impertore
In my headlight engine, I bought the original knob at the tip of 40 TL. I made the adjustment, the headlights are looking at the cross right now
