Help for choosing the rim for 206
08.05.2020 14:02 # 1
SelmanBeber
Hello friends; I have a 2004 206, the wheels of the vehicle are standard rim iron rim.
I am going to fill the fender (I will get the original rim if I find it) I am thinking of buying 16 inch wheels but I could not decide exactly. I would make a mistake by taking 16, would performance decrease or would be friction. But I want mud to look aesthetically pleasing to the eye ...
I am waiting for your ideas and suggestions ..
Thank you from now..
08.05.2020 14:02 # 2
GokhaN
I think the rims in the form of wind rose known as 206 quiksilver for 15 or 206 cc rim would be nice if you press the car, it looks nice and you won't experience much difference in performance.
08.05.2020 14:02 # 3
HakanGokdemir
According to your budget, it's actually a rim event.
If the car is 1.6, I would buy it without thinking 16 "but if it is 1.4, I would say take a 15" alloy wheel. These include wind rose, 206 gti or end point 206 RC rim ...
I have my rims without forgetting Hee LOL
08.05.2020 14:02 # 4
hakan brother's rims are very beautiful in 206, i recommend my friend.
08.05.2020 14:02 # 5
SelmanBeber
If you press the car 1,4, that is, let's shorten my springs or let's take a nap. Meanwhile, some of the friends said that they would destabilize the bow shortcut.
what do you think
08.05.2020 14:02 # 6
MirakGTI
the best 206 gti rim is 5 inches sports bow in 15 inches I think number 10 ..
08.05.2020 14:02 # 7
hasimayaz
[QUOTE = r3el] When you press the car 1,4, let's shorten my springs or let's take a nap. Meanwhile, some of the friends said that they would destabilize the bow shortcut.
what do you think
Neither heat nor short. sports bow even coil if possible
08.05.2020 14:02 # 8
SelmanBeber
I looked at the rims of our hakan friend. There is also a shipping cost, as it is definitely certain to be attached to customs. they want invoices, if they don't have invoices, they operate according to their conscience and the price on their heads, no one can say anything. illegal laws of the illegal country.
I bought a pioneer 3050 200 TL from the cargo. They said that this product will not be 200 TL even though I have an official invoice in hand.
Then we watched the real show inside the customs building and spent the day at the police station. but as a result, they bought 144 TL customs for 200 TL product.
Have money.
08.05.2020 14:02 # 9
MirakGTI
it would be better if you came to Istanbul and did shopping =) Put the wheels on the luggage and go .. :)
08.05.2020 14:02 # 10
HakanGokdemir
There is a lot of tafarruat, no effort in customs, shortening the spring or shortening it by heating creates the opposite effect of dropping the vehicle. One of the reasons for dropping the vehicle is to increase the image and road holding, but if you cut or heat it down, the springs will lose their property, and I do not say anything else. The most economical thing to do is to buy a 3.5 mm sports spring, the best brand of these is to buy the EİBACH HELEZON SPOR YAY, but this may not reduce your vehicle to the extent you want. If you buy a spring of 5 or 6 cm, you also need to replace the vehicle's shock absorbers with a sports shock absorber. Otherwise, existing shock absorbers will explode at a possible blow. But I am willing to pay, I have money, as long as you want to get something as I want, you will wear it as Haşim says, you will enjoy the coilowers ...........
By the way, I don't know if you know, but the front suspension of the 206's is the spring-loaded rear suspension. So you will put the bow on the front and you will lower the torsion on the back of the master ...
hakan1203 2009-03-30 15:46:39
08.05.2020 14:02 # 11
HakanGokdemir
what do you think
Depending on the process you are going to do, the word may be wrong, as a result, if it says only images and you are running away from the expense, the biggest problem of peugeots is their front teams.
08.05.2020 14:02 # 12
SelmanBeber
I HAVE MORE THAN MY MONEY, JUST WHAT IF I CHANGE THE WHEELS.
WHICH HAS 1.4 ENGINES, 15 WHEEL RIM IN THE CAR, SPORT TIRE TO SEE IT. YETMEZMİ NOW
08.05.2020 14:02 # 13
HakanGokdemir
My car was a 206 xt 1,4 2003 model and I wore a 15 "rim more than usual.
If you want to try it, meanwhile pay attention to the offset ratios when buying rims, if you are not going to buy the original peugeot rim.
08.05.2020 14:02 # 14
Emin
206 You'll Break the Money
YOU WILL BUY 206 RC WHEEL ..........
08.05.2020 14:02 # 15
berko
206 gti or quick rim and 3.5 or 5 cm spring super standing. In my vehicle there are member vehicles, if you want to look at it, the idea is formed at least. Let the bidet loose 15 to minimize performance loss and look good.
berko 2009-03-30 20:26:59
08.05.2020 14:02 # 16
SelmanBeber
yes 15 inc. it will be the most beautiful in my opinion. Well, 5mm bows do not lower too much, that is, when 3 people or 4 people get back to the fender.
If you have 5mm spring pictures in your hand, I would like to add it.
08.05.2020 14:02 # 17
HakanGokdemir
If you buy a sports bow, it will come in 2 pieces, and make sure that even the 5 cm drop in front of you may not give you the desired drop. If the backs are torsion, you will take him to a master who understands the work, without changing any parts, the room that will make you drop only by dropping the torsion teeth. It will help you to the following place about torsion ...
08.05.2020 14:02 # 18
HakanGokdemir
By the way, if you remember that I wrote earlier, you will need to change your shock absorbers if you put more than 4 cm of short springs. Or you should use the car very gently with your existing shock absorbers, otherwise the head may hurt due to front tool problems and shock absorption.
08.05.2020 14:02 # 19
SelmanBeber
no brother 5 mm is good. And I can't deal with the shock absorber for now. I don't want it to stick to the ground anyway, I just want it to be a little more ergonomic with new wheels and tires. Unfortunately, our country roads do not like cars near the ground anyway :).
so if you attach a 5mm spring you don't need to change the shock absorber.
Meanwhile, 206 pictures with 5mm attached.
08.05.2020 14:02 # 20
HakanGokdemir
[QUOTE = r3el] no brother 5mm is good. And I can't deal with the shock absorber for now. I don't want it to stick to the ground anyway, I just want it to be a little more ergonomic with new wheels and tires. Unfortunately, our country roads do not like cars near the ground anyway :).
No dude just the opposite, if you wear 3.5 or 4 cm, no need for shock absorbers.
I have a picture but I do not know my side. Let me add it for 10 minutes.
Page : / 2
