Help for 307 lpg ... 2, topic
08.05.2020 15:00 # 1
kaan__
good evening to everyone 2004 i have 307 sw vehicle
I bought the car 2 years ago, until last year, the vehicle that I got into lpg smoothly, whatever happened was that it did not eat gas, traction difficulty, failure lamp, etc. Service of this romano is unfortunately nobody who understands, nobody has anyone who understands, lpg problems in Peugeot. it happens again as if it was programmed again ....
In my researches in general forms, various solutions related to this subject have been explained.
SOLUTIONS AS FOLLOWS:
1-COIL EXCHANGE
2-THROAT BUTTERFLY CLEANING
3-INJECTOR CLEANING
4-OXYGEN POST CHANGE
REPLACEMENT OF 5-LAMBDA SENSORS (2 PIECES HAVE FAILED)
6-THERE IS A FILTER THAT GOES TO THE AIR FILTER, CLEANED THAT IS CLEANED (CLEAR I DO NOT UNDERSTAND)
7-95 octane gasoline should be used
8-REPLACEMENT OF GASOLINE IF THESE ERRORS ARE TAKEN
9-EXCHANGE OF EXHAUST PRESSURE SEAL
10-SIGNAL CHANGE CONNECTED TO 4 CABLES ON THE MANIFOT
11-YOU NEED TO KEEP OIL ON THE GAS QUARTER
12-VEHICLE SOFTWARE CURRENTLY DELETED FROM THE BRAIN FROM THE BRAIN
13-Most of them are unnecessary, and a good master needs to adjust the calibration
GOD'S SOMETHING NOW I HAVE TO MAKE WHICH OF THESE I CAN RECOVER FROM THIS FAILURE AND LOW PULL
I THOUGHT TO DELIVER THE VEHICLE (MOUNTAIN CEY LPG CONVERSION) TO THE ANKARA AND ASSEMBLE THE LPG AFTER THE YEAR'S NEW YEAR.
I WAIT FOR YOUR AID OR SOLUTION PROPOSALS Ağlama
08.05.2020 15:00 # 2
only_younus
I do not know if it is the same with your problem, but after the tube was installed, the car tachometer fluctuated while idling, it catalitic convertor fault and anti pollution fault. When I played it again, anti pollution fault was like a ball of light.
08.05.2020 15:00 # 3
g-demir
It doesn't matter if you burn a lot and give it the power you want. My lion now has "Antipollution Fault" but burns 17 cents per km: D
08.05.2020 15:00 # 4
kaan__
Yes, my friend, in the same way, I thought that the LPG consumption has increased a bit and I made a setting. I gave it 20 lira.
I did not do that, I even offered a remote desktop connection, they said okay not to go there until now.
anyway thanks anyway.
08.05.2020 15:00 # 5
kaan__
In the meantime, I apologize to the management, I opened the issue 3 times, but I was unable to delete it again.
