Help dripping water under the torpedo!
08.05.2020 14:08 # 1
Orhan
In the night, I would clean the interior of the car, remove the mats, right, the front mat was soaked.
08.05.2020 14:08 # 2
peugeotefe
can make from heating radiator
08.05.2020 14:08 # 3
hasimayaz
As if buying from door tires. As it is understood from the photo, the tires are slightly deformed. (meaning crushed)
08.05.2020 14:08 # 4
cerci07
door made of tires, my 206 also have the same problem
In rainy weather, if I park on the road on the left and the right on the left, it will be like the aquarium inside the car. Unhappy
08.05.2020 14:08 # 5
Onur
door wicks are most likely
08.05.2020 14:08 # 6
deniz_206
door wicks look worn.
08.05.2020 14:08 # 7
shamed
My mats are not carpet-style rubber, feet are wet in the rain, naturally it is wet in the mat, but the aquarium style is not like you did. Thank goodness.
08.05.2020 14:08 # 8
GurbuzBAYRAM
Most likely it is caused by the radiator. Look at what time it is doing .. Look at it when it runs, for example ..
08.05.2020 14:08 # 9
shamed
Did you find out why the problem is?
08.05.2020 14:08 # 10
kocvizyon
IF THE DOOR ADJUSTMENT HAS BEEN SHIPPED THE DOOR IS NOT COMPLETELY THE SAME WAS COMING TO ME I WAS RING TO THE PASSENGER NO WAY ON THE ROAD I was taking the wind I hope the problem is solved.
08.05.2020 14:08 # 11
BuRCaK
Have I ever disassembled the torpedo?
08.05.2020 14:08 # 12
Orhan
I left the car for 10 thousand maintenance, I did not ask the master why he made the service there; Bat007 torpedo was not dismantled at all ..
08.05.2020 14:08 # 13
bbcb
As far as I know, the left side and the central heating can be yours on the right side, there may be door and glass wicks, and the rain inside the engine etc. There are holes for drainage of water, as it may be clogged
