Help Contact is turning but no click
08.05.2020 20:32 # 1
Ozgur hoca
Arkasas need urgent help 2003 70 horsepower 307 hdi my car changed the press brake lining time 4 months ago, the vehicle changed at 175000 km and after 2 months, I put the car back in the car and 15 minutes after I put the car in the ignition, and when I turn it, I put the key back on the ignition and when I turn it, there is no sound or starter. When I turn the starter, the battery lamp goes out but there is no click, I pulled the car, it worked, and it was okay, only two months later, if the same problem was found again, I hit it and started it, but when I closed the car, the same problem is happening again. In the meantime, the battery is new and I tried to reinforce it as if the car did not protect itself. like it took but why
08.05.2020 20:32 # 2
hzr206
Starter coal could be similar situation happened in my old car
08.05.2020 20:32 # 3
Orcun.Dmr
Starter motor does not work due to running out of coal.
08.05.2020 20:32 # 4
Ozgur hoca
Well, when he did it for the first time, when I hit the car and started it, it went 2 more months. Could it be like this when the starter coal is finished?
08.05.2020 20:32 # 5
ALLEX
Hodja, be late.
First, check if the battery terminals are loose. Even if you operate it with reinforcement or knocking, the polar head will not be able to fill the battery when it is loose.
Secondly, if the battery is depleted, it does not hold charge and does not start as there is not enough amps to start again.
Thirdly, the strong possibility is that the alternator is defective and does not charge the battery.
All you have to do is get the battery and alternator control to the auto electrician.
I hope you will fix the problem as soon as possible and share the result under this heading.
In this way, if there are people who experience the same problem, your help will be touched. Have a good holiday again.
08.05.2020 20:32 # 6
Ozgur hoca
https://youtu.be/2apSMaFiA6U I uploaded the video, I am very happy if you help me, I am sure that there is a lot of people who experience this problem. no tick
08.05.2020 20:32 # 7
Ufuk_64
It used to be in my car of another brand. I have to do it as written but very carefully. The best tool is a long crowbar. One person will hit the starter dynamo in a person who will get into the car and turn it as if it is two times per second. Of course, it is necessary to make a little plan to find the starter dynamo.
08.05.2020 20:32 # 8
hzr206
It was my car hammer, we came to the mechanic, the car worked, I think the coals in the starter were changing, but it won't be long lasting, you will always hit it.
08.05.2020 20:32 # 9
whisky
The starter motor can remain stuck, there is coal, probably already, yes it was solving, it happened to me.
08.05.2020 20:32 # 10
Ozgur hoca
Yes, the problem is that the right starter dynamo was stuck, a few blows of Turkish style to the mars dynamo, but I will go to the electrician for the exact solution.
08.05.2020 20:32 # 11
Orcun.Dmr
Have the starter motor checked for chassis. Sometimes the starter motor does not come on because it cannot take the chassis and complete the circuit.
