Help About Triger ... |
| 08.05.2020 16:14 | # 1 |
| 08.05.2020 16:14 | # 2 |
how many km of vehicle
| 08.05.2020 16:14 | # 3 |
Long Beach |
Keep your vehicle away from the master (!) engine downloading engine for triger & nbsp; & nbsp; your voice, if If you are sure that it comes from the timing (the tiger does not sound actually), it is the tensioning ball that makes the sound, it is not expensive and its change is 15 minutes. There is no need to download an engine too long. The sound that you think from the timing can also come from the dynamo belt. Check it. TP = tensioner + ball tensioner bearing / ball |
| 08.05.2020 16:14 | # 4 |
Thanks & nbsp; The vehicle comes from 140 thousand, and the sound comes from the triger, the 2 masters say the same thing.
| 08.05.2020 16:14 | # 5 |
I do not understand how there is no fear of Allah in these masters. Man is afraid of God while he says this. Long Beach friend already told you in detail. is either on the tensioner ball or on the alternator belt. expensive place .... whatever they are diagnosing. my car is 34 license plates. ... spoils the employee and gets 5 if the expense is 1 ... |
| 08.05.2020 16:14 | # 6 |
[QUOTE = Ahmet] Thank you & nbsp; the vehicle comes from 140 thousand sound, the trigerin comes from there 2 masters say the same thing triger 2 thousand years ago, the guy I bought says he will repeat it. Reviews
| 08.05.2020 16:14 | # 7 |
tomorrow I will take it to the service, the master does not deal with it, he says differently he says differently
| 08.05.2020 16:14 | # 8 |
Long Beach |
[QUOTE = koliva] [QUOTE = Ahmet] thanks & nbsp; the vehicle comes from 140 thousand sound, the trigerin comes from there 2 masters say the same thing triger 2 thousand years ago, the guy I bought says he will repeat it. [/ QUOTE] There is no network for the trigger not being installed correctly after the required technique has been followed. = "Language Extraction" title = "Language Extraction" /> or & nbsp; The tooth has missed, it has missed the synthesis, that is, the motor falls out of pull, which does not cause sound. My guess is still the tension ball or dynamos. |
| 08.05.2020 16:14 | # 9 |
there is no problem in the traction or going, I will show it to the service.
| 08.05.2020 16:14 | # 10 |
If the sound from the timing is too bored, the ball will make a tough whistling sound.
| 08.05.2020 16:14 | # 11 |
For a sound coming from the timing absolutely and definitely, the engine does not come down. Also the belt does not make sound, but the tensioner ball or pulleys make the sound. div id = "isChromeWebToolbarDiv" style = "display: n o ne">
