Help About Speaker Cable |
| • Homepage » PEUGEOT MODIFIED PLATFORM » Peugeot Sound Systems | |
| 08.05.2020 19:54 | # 1 |
| 08.05.2020 19:54 | # 2 |
OguzhanKucuk61 |
I don't know the speaker. I pulled the cables under the armpits for the backlight lighting. I don't think there will be a problem
| 08.05.2020 19:54 | # 3 |
Alicilik |
I think 0.75 ideal up to 30w rms |
| 08.05.2020 19:54 | # 4 |
Thanks for the answers, the speakers are 30 w rms exactly. There is no problem in my installation right now. No need to be broken. Then I recommend friends to use 0.75 or thinner insulated cables for the sake of originality. It is not suitable for passing through the socket without modification. By the way, I removed it from the armpit and wandered around its cables. I realized that the sheet of that part was getting hotter than other places. |
| 08.05.2020 19:54 | # 5 |
Alicilik |
There are empty pins in the socket, it can be done there with the new terminal.
| 08.05.2020 19:54 | # 6 |
You are right, this kind of application is easy, there is a lot of space that can be pinned in amateur of course. It would be nicer, it would be better if those who love to deal with and who can provide complete material do pin. |
| 08.05.2020 19:54 | # 7 |
I do not have a 2005 x-line rear speakers in my vehicle. Will the door trims be removed to install speakers only? |
| 08.05.2020 19:54 | # 8 |
If there is a rear speaker wiring in the vehicle, there is no need to do anything after the appropriate connection is made to the tape and the speakers are connected. As a matter of fact, the original tape does not exceed 15 minutes if these wiring is required. But if there is no wiring, it is necessary to pull the cable, it is necessary to use the appropriate material and to know the vehicle. |
| 08.05.2020 19:54 | # 9 |
Friends, I said to write here to avoid new issues, there is a 2001 model 206 xr, there is no speaker in the rear doors, but without telling whether the installation is there or not, what color cables will be loud by the hose between the door between the door and how many cables will be used in the vehicles with the installation.
| 08.05.2020 19:54 | # 10 |
Look at the speaker socket coming to the tape before the door socket, if there is 4 wires in the speaker socket coming to the tape, only the installation is pulled for the front doors. Vehicle owners with plumbing can help in more detail.
