Help About Spark Plug?
08.05.2020 16:21 # 1
B-Devi
I have lubrication on my 3rd and 4th spark plugs. I took pictures, can I get your feedback:) You can click the URLs below to enlarge the pictures. Bujihttp: //www.cnrbs.net/buji/1.buji-a.jpghttp: //www.cnrbs.net/buji/1.buji-b.jpg2. Bujihttp: //www.cnrbs.net/buji/2.buji-a.jpghttp: //www.cnrbs.net/buji/2.buji-b.jpghttp: //www.cnrbs.net/buji/2. plug-c.jpg3. Bujihttp: //www.cnrbs.net/buji/3.buji-a.jpghttp: //www.cnrbs.net/buji/3.buji-b.jpg4. Bujihttp: //www.cnrbs.net/buji/4.buji-a.jpghttp: //www.cnrbs.net/buji/4.buji-b.jpgNOTE: They were left there because I could not delete the pictures below. :)) B-Devi2011-11-12 19:37:19
08.05.2020 16:21 # 2
sedatdatse
But it seems that the spark plugs are obsolete
08.05.2020 16:21 # 3
B-Devi
There is lubrication at 3 and 4
08.05.2020 16:21 # 4
So what is this indicative? There is definitely a problem that is why it is oiled.
08.05.2020 16:21 # 5
B-Devi
I'm asking him exactly :)
08.05.2020 16:21 # 6
I do not feel bored, but I know that it is not a good sign.
08.05.2020 16:21 # 7
insomnia
I wonder if there is a loss of compressor loss in the vehicle.
08.05.2020 16:21 # 8
B-Devi
No oil does not subside. More precisely, I never used the car after the spark plugs were lubricated. It already works by singing. As 3 pistons work
08.05.2020 16:21 # 9
Is your vehicle still kicking with new spark plugs now?
I don't see much trouble with spark plugs. Their color and condition are good.
How many spark plugs have been used in one?
koliva 2011-11-12 21:33:10
08.05.2020 16:21 # 10
B-Devi
I don't know how long it was used. I brought the biker to look at the vehicle and he put them on. Mine took me away. I did not buy the new spark plug, I just removed the ones on the vehicle. to take pictures and ask you. I clean it with lining spray. Tomorrow, I'll put some sandpaper down and put it on. In the meantime, after removing the spark plugs, I sprayed lining spray into the pistons. In order to clean the oil inside. It dries up until tomorrow. Let's try it, I hope I'll be successful :)
B-Devi 2011-11-12 22:03:08
08.05.2020 16:21 # 11
Kemanyak
I would like to have a look at the ignition coil in the first place. 2. I don't even want to say it, but your circus is over.
08.05.2020 16:21 # 12
B-Devi
[QUOTE = Kemanyak] I would like to take a look at the ignition coil in the first place. 2. I don't even want to say it, but your circlips are finished. [/ QUOTE]
If the rings are over, I will not be able to do it. It makes more sense to have a complete engine :)
08.05.2020 16:21 # 13
Kemanyak
Then there must be a smoke problem. I think there may be problems like ignition advance settings. Because this type of oil is an indicator of an unburned fuel problem. Have a coil checked first.
08.05.2020 16:21 # 14
B-Devi
[QUOTE = Kemanyak] Though, then there must be a smoke problem. I think there may be problems like ignition advance settings. Because this type of oil is an indicator of an unburned fuel problem. First check a coil. [/ QUOTE]
Ohh I can't explain how I am relieved :)) We have no smoke problems, thank goodness. It only works by shaking. In the car, the valve adjustment was broken, he was hitting idle, and he was snapping. Somebody said he could do it from valves, then I was relieved :) Finally, I have to find a veteran. I am 100% sure that the gas setting of the car is bad. What can he do to me?
08.05.2020 16:21 # 15
Ucyuzalti
Have not yet made the lpg setting & nbsp; "Grin" had said before setting condition & nbsp; "Laugh"
08.05.2020 16:21 # 16
B-Devi
I'm not starting the car at all. Laying in front of the door "Grin"
