Help About Peugeot 406 Sport Pack ... !!!
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 14:16 # 1
Hello there,
I also joined the Pejoists. I have a few problems with my vehicle I bought 2 months ago. I ask for help from friends who have knowledge about the subject.
2001 model 2000 Hp, 138 Bg Sports Pack model;
1) There is no LPG in my vehicle. Since I use the company vehicle, I do not have the opportunity to use 406 more. I traveled 400 KM in 2 months :)) I do not think of getting LPG because I don't use too much and because of financial difficulties. But my problem burns around 0.50 Kurus per km (may be more) :)). Do you think this value is normal?
2) I'm having trouble with my tape. Although I turn off the ignition once in a while, my tape does not turn off. The steering control and the tape on-off button do not work. But I can change the channel over the tape and turn on and off. I never managed to turn off the tape. As a solution, I removed the battery terminals and fixed them. But it is inconvenient to remove the battery terminals. Also, this solution is laborious and I have to adjust it again because the settings are reset. What do you think is the problem in my tape? Does it cost me a lot?
3) I have to pay around 410 TL this month. According to what I heard from a friend, if I fill out a "Declaration" and give it to the tax office, I can deposit taxes from a lower tier . How can I do this and what are the conditions?
4) I had the maintenance of the vehicle (oil, filter, water, shock absorber etc.). But I made it to the mechanic instead of an authorized service. I heard that I had to connect it to the computer and reset the maintenance date or something. Do I need to take the vehicle to the service?
Thanks to Everyone in Advance ... !!!
salmankar to 2010-06-10 09:46:16
08.05.2020 14:16 # 2
serkan.ist
I am a 135 hp 2000 st user.
Its fuel is normal for the city. It burns between 300 and 300 with LPG.
You do not need to have the maintenance date connected to the computer. In the booklet it says how to reset with the control keys. It's an easy process.
serkan.ist 2010-06-09 21:49:30
08.05.2020 14:16 # 3
Serkan Bey, thank you. I don't have the booklet of the vehicle. Can you tell me how I can do it if it is not very difficult?
I'm waiting for urgent help from friends who know about other issues ... !!!
Respects
08.05.2020 14:16 # 4
serkan.ist
I don't know by heart. When I take the booklet out of the car, I will send you that section. I think there is no difference with yours.
08.05.2020 14:16 # 5
serkan.ist
As I said the process was very easy
Turn off the ignition. Press and hold the 000 button on the speed panel display next to the temperature indicator (I think it may vary depending on the model) and switch on the ignition.
The km display screen starts a reverse counting of 10 seconds.
One of the buttons (the button with a 000 km button) is pressed continuously for 10 seconds. The display = 0] indicates `and the maintenance key disappears. (when the maintenance time approaches, for example, when 500km is left, a key sign appears next to the km indicator)
So it's an easy process. I hope it helps.
serkan.ist 2010-06-17 20:59:46
08.05.2020 14:16 # 6
Thank you, I will try it when you go home. I hope I can ...
08.05.2020 14:16 # 7
fatihsun
the same vehicle I bought, I have the problems you said.
Did you find a solution, it is very frustrating that the radio does not turn off good day
08.05.2020 14:16 # 8
fatihsun
I wonder if there is anyone else who has this radio problem
