HELP ABOUT GASOLINE TANK :( ???
08.05.2020 15:10 # 1
volkan22
Greetings to all, friends
my tool 306 2.0
the gas tank of my car is vacuuming and the petrol nozzle is burning even though I have petrol in my car
then I say "open the gas door" (fiss)
Gasoline needle freezes to normal when the lid is open after fissss
When I got the vehicle, the cable in the picture was off
I SAID A TEAM IN PLACE AGAIN WHEN MEYER PLUGS IT TO THE HOSE, THIS IS A PROBLEM.
VALVE HOSE HOSE SQUARE GASOLINE COVER CLOSED HERSEY NORMAL
BUT THE VALVE E IN THE PICTURE TAKES THE HOSE I GET THE GASOLINE TANK VACUUMED AND THE GASOLINE HEIGHT IS ON
If you help, thank you.
08.05.2020 15:10 # 2
volkan22
http://img708.imageshack.us/i/peugeot306gti6engine.jpg/
BUDA BUDA PICTURE FRIENDS
08.05.2020 15:10 # 3
peugeotefe
First of all, the canister of the vehicle should be checked, a black piece in the right front fender may have a problem (broken, cracked or absent, etc.). If there is no problem, the valve should be replaced
08.05.2020 15:10 # 4
volkan22
I do not think there will be a problem with that when the hose is attached to the box, the gasoline tank is vacuuming
If it is broken or clogged, I think the gas should not be pressurized.
When I try to overtake the other, the valve sucks my hand when I put my hand on it and I do not know that it will be a problem.
Because when you insert the valve over it, it falls from the car age and gets better.
When the hose is inserted because it is plugged, the tank is vacuuming.
08.05.2020 15:10 # 5
volkan22
can be from the valve but I can't find another valve around here because I don't stay in Turkey
Do the valves of other vehicle models stimulate this?
08.05.2020 15:10 # 6
peugeotefe
You do what I say then you write it down. The piece in the fender that I call the canister draws the vapor inside the gas tank by vacuuming, and according to what you tell, this part does not function, is the gas tank making air?
08.05.2020 15:10 # 7
volkan22
yes it makes air and even though there is gas in the car, the gas light is on when the light is on
I'm stopping the car, I'm hurting the cover of the gas
I am going to have a brother like you said
Thank you so much for your help
08.05.2020 15:10 # 8
peugeotefe
As soon as the god bless you, the vehicle may burn due to compression in the gas tank
08.05.2020 15:10 # 9
volkan22
Also, the car eats gasoline, the one who eats and sees the question, says you use me ferrar: S
I was able to go 25 km to 8 liters of gasoline: the petrol gauge does not stop somewhere 1 up and down: S
08.05.2020 15:10 # 10
If we told you about another subject before. The canister valve doesn't work because it is faulty. he does this problem when he doesn't work ...
08.05.2020 15:10 # 11
volkan22
Unfortunately, Cecoli Sister Ask the canister
does not absorb gasoline vapor and the car runs from it late in the morning
car driver canister watering but we couldn't find a canister here
Maybe it is because of him.
Also, I couldn't find any other canisters for the repair chance of the canister: S
volkan22 2011-03-22 19:51:22
