Help About 106
08.05.2020 21:17 # 1
tolgahanbulut
Selam aleyküm brothers, such a pipe comes out of the manifold part of my vehicle, the tip was idle and I just noticed. Idling was running high between 10 thousand 11 thousand and constant fluctuation is present.
Spark plug and cables changed
-Oil filter, oil just changed
- Butterfly throat was cleaned, adaptation was made.
Valve setting is done
-Gaz brain, electrical installation reset
Idle engine zero
Idle clogged, the idle dropped to 8 thousand but the ripple still exists. Is it a problem if this pipe is clogged or open?
Pictures are in the attachment.
