Help. |
| 08.05.2020 20:24 | # 1 |
| 08.05.2020 20:24 | # 2 |
Looks like a tweeter ![]() Do you hear any sound?
| 08.05.2020 20:24 | # 3 |
No, I wish he came: D
| 08.05.2020 20:24 | # 4 |
Check the cables they cut
| 08.05.2020 20:24 | # 5 |
[QUOTE = Uzunca961] Check the cables have cut [[QUOTE] Hmm then it is sure to be the tweeter. I do not know where and how to do. No original tape. I already bought another tape with an electrician.
| 08.05.2020 20:24 | # 6 |
maximusti |
Tweeter. It goes down through the pole to the front fuse box. The cables are going from there either to the door loudspeaker or directly to the tape recorder. |
| 08.05.2020 20:24 | # 7 |
Let's take the salary, let me take a look, then: D
| 08.05.2020 20:24 | # 8 |
Nothing to look at, actually. You can not get in. Disconnect the plastic from there follow the cable directly depends on the speaker 90%. If it is not connected, you are tied up, I know that you do not need to do anything extra
| 08.05.2020 20:24 | # 9 |
[QUOTE = uzunca961] Nothing to look at, actually. You can not get in. Disconnect the plastic from there follow the cable directly depends on the speaker 90%. Even if it is not connected, you know that you do not need to do anything extra. You can do it.
| 08.05.2020 20:24 | # 10 |
doganatak |
Can there be an internal sensor if there is an alarm? This was the interior sensor of the alarm of the previous car
| 08.05.2020 20:24 | # 11 |
No alarm, sir. I didn't think it was actually, but there is no alarm installed.
| 08.05.2020 20:24 | # 12 |
Alarm sensor.
| 08.05.2020 20:24 | # 13 |
ggitaristt |
These are like the ultrasonic motion sensor that friends say .. Parts of the car alarm .. |
