HELP - 307 Stopping idling in gasoline vehicle
08.05.2020 16:41 # 1
martesque
Greetings to everyone, I have a problem with my car, I live in Istanbul, my 303 Manual Gear - My gasoline car stops especially at high altitudes, for example when I go to Ankara, Fethiye when I go up to 1000 M altitude, when I go to Bolu (last time I go to Kartalkaya) the car stops. There was no problem using the car in Istanbul, only a few times I had a problem in the underground car parks of the shopping malls, once I experienced the last day while parking in reverse gear in Ümraniye. When I showed the vehicle in Ankara, a master said that it might have been caused by air, and then I took it to Peugeot Tekoto 2-3 months ago, they connected it to the computer, they said no problem. Delpollution displays faulty message on the screen after stopping at idle. I read comments from the forum and the internet, some said that it might be related to the software, I do not think that it is in my car, there should have been a problem in Istanbul, I always take it to peugeot authorized services, they never told me the software update, it is written that it may be caused by the following malfunctions from the forum and the internet, Throat throttle contamination Idle sensor malfunction Absorption manfiold malfunction VSS sensor malfunction oxygen sensor malfunction idle valve malfunction problem in certain environments especially interesting in high altitude, if there is a part malfunction you would expect it to be a problem everywhere but I did not understand why ???? Does anyone have experience with this? Are there any masters / services you can recommend? When I take it to the service, they say it is okay because the car did not stop, but my car stopped on the icy ground, I stopped officially on the icy ground, the vehicle was too risky to stop, I am afraid it might happen to me in an accident. I think you may be asking your comments tsk martesque2012-04-06 10:49:43
08.05.2020 16:41 # 2
First, I would have the MAP sensor checked. The number 5 track in the picture below.
