Help 307 bsi brain
08.05.2020 20:23 # 1
samet2461
good day everyone. my vehicle bsi brain has taken water from the water channel and bsi brain is causing problems. my rain sensor, my headlight sensor is not activated, the horn does not work once in a while and there are a few problems that I cannot think of. we brought this brain out and tried a few times but it is not compatible. They take the imo presentation and wear it to the other brain. We said, let's get zero. I ask for help. 307 xt 2004 1.6 hdi
08.05.2020 20:23 # 2
It is a difficult situation. How many parts have you asked?
08.05.2020 20:23 # 3
Aleynaboyner
I was in the 307s and I did not like it anyway. Look, troubled cars get past ..
08.05.2020 20:23 # 4
onlycihan
[QUOTE = Aleynaboyner] I have 307's possible I did not like it anyway. Look, troubled cars get past ..
you said it was as if 206s got zero problem :)
08.05.2020 20:23 # 5
Aleynaboyner
Brother old thing. There is nothing to do. It is necessary to look when it is old. I was joking. My car's brain is gone.
08.05.2020 20:23 # 6
sdttn
Have you researched to have it repaired?
08.05.2020 20:23 # 7
samet2461
[QUOTE = sonerkyl] Difficult situation you asked how many particles do you just have to do parts research inside the city =?
they said I talked to this site; we want to come from france, my brother, but he may not fit he said we can not guarantee
08.05.2020 20:23 # 8
samet2461
[QUOTE = sdttn] Have you researched for repairs? [/ QUOTE]
we did but it was always oxidized
08.05.2020 20:23 # 9
sdttn
[QUOTE = samet2461] [QUOTE = sdttn] Have you researched for repair? [/ QUOTE]
we did but it was always oxidized [/ QUOTE]
Yahu, you had an ABS problem, right? How unlucky you are.
These BSIs are not plug-and-play, they need to be programmed according to your vehicle, and I know that programming is done with peugeout's own diagnostic device, Lexia.
How did you do while trying out BSI? Without programming?
08.05.2020 20:23 # 10
whisky
My friend is not the problematic 307, you should entrust your vehicles to the masters like the problematic butcher and behave carelessly. Most of the things that come because of the jobless masters, the man makes room for the sound wireless lpg or something, and the cable he opens does not cover the place with silicone, if the rain or wash water is too much, water escapes through the hole and this causes the bsi to get wet. throwing a silicone there won't even cost 1 TL. but the butcher masters are not aware of this. In order not to oxidize, it was necessary to remove the battery terminals and the bsi and dry them well, and take the breath to the brain. Get well soon whiskey 2017-06-02 08:41:30
08.05.2020 20:23 # 11
boruc
Get well soon. If you were in Bursa, I could be directed to a master, but I think you are in Trabzon.
08.05.2020 20:23 # 12
samet2461
yes there was an abs problem and we solved it and it turned out. I wanted to have it done in the service, I said, let me give you money, even the service said we can not find your brain. what should I do now. I am out of town in case of duty, I'll switch to the holiday, give me an idea, let me do it while on leave!
08.05.2020 20:23 # 13
sdttn
BSIs should be exactly the same as the Hardware version.
The dump of the eeprom from the old BSI will be taken and programmed to the new one.
So you have to go to the place that makes electronic brain repair. Plug and play does not work.
08.05.2020 20:23 # 14
samet2461
[QUOTE = sdttn] BSIs must be exactly the same as the Hardware version.
So where can I go to Ankara in 20 days? somewhere you know you know. If it resolves within 1 day, I will get it done
08.05.2020 20:23 # 15
Peugeot35
My teacher, is this part of the brain that I marked in the picture?
08.05.2020 20:23 # 16
Peugeot35
[QUOTE = samet2461] good day everyone. my vehicle bsi brain has taken water from the water channel and bsi brain is causing problems. my rain sensor, my headlight sensor is not activated, the horn does not work once in a while and there are a few problems that I cannot think of. we brought this brain out and tried a few times but it is not compatible. They take the imo presentation and wear it to the other brain. We said, let's get zero. I ask for help. 307 xt 2004 1.6 hdi [/ QUOTE]
teacher 307 quit brains if you want to search and present problems in the link I provided.
08.05.2020 20:23 # 17
samet2461
[QUOTE = Peugeot35] teacher, is this part of the brain that I marked in the picture?
yes the brain there
08.05.2020 20:23 # 18
samet2461
[QUOTE = Peugeot35] [QUOTE = samet2461] good day everyone. my vehicle bsi brain has taken water from the water channel and bsi brain is causing problems. my rain sensor, my headlight sensor is not activated, the horn does not work once in a while and there are a few problems that I cannot think of. we brought this brain out and tried a few times but it is not compatible. They take the imo presentation and wear it to the other brain. We said, let's get zero. I ask for help. 307 xt 2004 1.6 hdi [/ QUOTE]
I ask, tomorrow, teacher, I will give information from here
08.05.2020 20:23 # 19
Peugeot35
[QUOTE = samet2461] [QUOTE = Peugeot35] is this part of the picture that I call this brain?
yes the brain there [/ QUOTE]
If it's a brain, where's the inner fuse box? One of your friends said that there is a separate metal part in the fuse box inside the engine that brain is.
08.05.2020 20:23 # 20
samet2461
[QUOTE = Peugeot35] [QUOTE = samet2461] [QUOTE = Peugeot35] is this part of the image that I call this brain?
that engine brain is what you call it. bsi brain, i.e. the whole electrical system that is defective in me (abs, esp, rain headlight sensor, horn, airbag etc.) is a brain that is all connected to it. When a system fails, everything is mixed. it's not a fuse box :). inssn is investigating a lot of malfunctions in the vehicle
Page : / 2
