HELP 307 ABS PROBLEM
08.05.2020 19:59 # 1
ARDADOGAN
Friends I have 2007 307 1.6 HDI manual gear
My problem is that the front discs and pads have been replaced with the original and the brakes are even at a terrible 20km speed. I wonder if he had an ABS sensor and the malfunction lamp does not light up. Please help if you have information
08.05.2020 19:59 # 2
Dralp
Hi, ABS is activated very early in pejoes. Your car has nothing to do with me.
08.05.2020 19:59 # 3
ggitaristt
301's brakes are very bad. But as soon as you walk 307 on the road, it stops where you step. Even with ice tires, I can stand without entering the abs.
Tires run out if abs enters early, or rot setting is bad, so something is bad Smile
08.05.2020 19:59 # 4
Peugeot35
[QUOTE = ARDADOGAN] Friends I have 2007 307 1.6 HDI manual gear
My problem is that the front discs and pads have been replaced with the original and the brakes are even at a terrible 20km speed. I wonder if he had an ABS sensor and the malfunction lamp does not light up. If you have any information, please help [/ QUOTE]
Hodja could be because the pad is new. The lining gets a little worn back to normal. 307 abs does not come into play easily, but if you press hard at 50/60 speed, use it a bit and decide.
08.05.2020 19:59 # 5
JunioR56
As our ggitaristt friend said, the tires may be depleted. I was afraid that the road handling is how it works but esp abs works perfectly. I do not use brakes in excessive bends. If the abs is activated as a crack, either the tires are dead or the brake adjustment can be very hard.
