Help 306 relay locations?
08.05.2020 17:17 # 1
selimc
Hello! When I pressed the resistance button of my car, I activated the fuse box as a result of the relay sound. The relay works when I press the button, but it does not go away when it is released, it did not throw itself. We changed the button, nothing changed. entry & nbsp; green relay installed. & nbsp; Green & nbsp; The 5-pin yellow relay was installed, but the green input is 4-inputs. And in the yellow entry & nbsp; There is a 5-leg black relay but & nbsp; & nbsp; logically yellow input yellow relay & nbsp; & nbsp; green inlet green & nbsp; no relay needs to be installed & nbsp; & nbsp; I tried so. This time, I had to plug the black relay into the resistance part, when it lasted, this time the resistance remained hungry as soon as the car started.
Show me a way, where is the real place of these relays.
Thanks in advance. Vehicle 94 model 306 xr
08.05.2020 17:17 # 2
selimc
nobody knows between you & nbsp; Can friends with 306 say relay locations
08.05.2020 17:17 # 3
It is true that you are saying. So the colors need to match. The part for the most beautiful resistance is to take a role in that color again.
08.05.2020 17:17 # 4
selimc
[QUOTE = koliva] That's the truth you're saying. So the colors need to match. To take part in the role for the most beautiful resistance again.
thank you & nbsp; Well, if anyone knows the values of the red relay, let's take it from the piece
