help ?
08.05.2020 17:23 # 1
Barut
I wish you a good evening first ...
if I come to my problem, I bought a rc challanger rim tire on the tire size 215 45. But it sounds like the calmness is calm, but the noise comes inside, the speed increases with the sound, and the buzz sounds from the front console and the speed increases with the speed. I am waiting for help from knowledgeable friends. I present my thanks in advance ..
08.05.2020 17:23 # 2
Barut
Is there a problem with the size of the tires?
08.05.2020 17:23 # 3
GokhaN
Measure tires on 17 rims in 206's should be 205 40 17.
08.05.2020 17:23 # 4
Barut
[QUOTE = GökhaN] Measure tires on 17 rims in 206's should be 205 40 17. It is likely to be made of tire. If there is no operation, if I take 205 40 17 in front, will it cause trouble in the back? & nbsp; thank you very much for your interest & nbsp; "Smile"
08.05.2020 17:23 # 5
GokhaN
[QUOTE = 206xs] [QUOTE = GökhaN] Measure tires on 17 rims in 206's should be 205 40 17. It is likely to be made of tires. If there is no operation, if I take 205 40 17 in front, will it cause trouble in the back? & nbsp; thank you very much for your interest & nbsp; "Smile" [/ QUOTE]
You should get rid of the
tires and get the proper tire. Don't worry about the hoods anyway. I've had some weight in the back, you hear the rubbing sound of all the bumps 206's a little bit of good news about it.
