HELP 206 shaky work
08.05.2020 18:53 # 1
cetintas
HELLO FRIENDS 206 XR MY VEHICLE IS SHOCKED AT LPG I DON'T THINK I HAVE A PROBLEM AT LPG VALUES AND INSTALLATION I HAVE MADE LPG IN 1 YEAR AND I HAVE LPG IN 1 YEAR, I HAVE LPG IN 1 YEAR AND GOT TO HAVE LPG IN 1 YEAR, I HAVE LPG IN THE VEHICLES, I HAVE LPG IN 1 YEAR, I HAVE LPG IN THE VEHICLES, I HAVE LPG IN 1 YEAR, I HAVE LPG IN THE VEHICLES AND GOT TO HAVE LPG FOR 1 YEAR, I HAVE LPG IN THE VEHICLES AND GOT TO HAVE LPG FOR 1 YEAR, I HAVE LPG IN ITS VEGET, I HAVE LPG IN 1 YEAR AND HAVE GOT TO HAVE LPG IN ITS LICENSE AND GOT TO HAVE LPG FOR 1 YEAR AND GOT TO HAVE LPG IN 1 YEAR, I HAVE GOT LP iGNITION cOIL to GIVES IF iGNITION cOIL DEFECTIVE IF I WANT I aM REPLACING I'm willing to HOWEVER nOT avail TRACK FEE PAYING FULL residing in ISTANBUL THIS MATTER AND MY VEHICLE iGNITION cOIL sUITABLE fOR BOBBIN USING tHE FRIENDS from AID wOULD tHE WEEKEND iS AVAILABLE fOR a FRIEND taking the me half an hour chance to try our MATTER I WOULD LOVE TO
I STAY IN ISTANBUL KUCUKCEKMECE
I wish you a good day
08.05.2020 18:53 # 2
cetintas
OR THE IGNITION COIL IS DEFECTIVE OR HOW DO WE UNDERSTAND THE SERVICE CONNECTING A PROBLEM CONNECTED TO THE PC
08.05.2020 18:53 # 3
Ali1905
What you say may be from valves, not the coil, pointing to it
08.05.2020 18:53 # 4
cetintas
does this only while working on lpg and idling, are they still valves?
08.05.2020 18:53 # 5
okaNStarss
let my help 1 do the same shake in the same way or in gasoline?
If it does, starting with the throat butterfly, you will find the spark plugs and the system by trying the spark plugs one by one .
If it does not work, unplug the injectors of the LPG one by one, whichever sound and vibration does not change, it may be problematic or you should check the cable system that came to it.
has been tried with experience. zavolide happened to me. The toyoto vehicle had a jerk, the three injectors changed 2 times, but the trouble was always checking the coil injector spark plug. But I insisted that I changed the ECU and the warranty was cut. So they say ecu is okay, but if you try it last, it feels like you will find my word. Some friends said the valve, but I know that it should sound mechanically, if the valve settings get scratched. so it has to be click. May it be easy.
08.05.2020 18:53 # 6
cetintas
thanks for your interest, but most of what you said has been tried
not on gas
throat butterfly cleared
Idle engine tried with a new one
spark plugs just changed
LPG injectors have been closed and opened from the system by the master several times.
08.05.2020 18:53 # 7
okaNStarss
have you changed the lpg ecu so have you always changed the injector
okanstarss 2014-11-19 15:44:11
08.05.2020 18:53 # 8
cetintas
I didn't change it. My first job is to try it.
