Help!!!!
08.05.2020 17:09 # 1
black_rock
& Nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; & nbsp; Friends, first of all, good Friday.
My friend has a problem like this: light oil is dripping from the upper cylinder gasket cover. & nbsp; & nbsp; & nbsp; & nbsp; Thank you very much in advance, I would appreciate if you help.
08.05.2020 17:09 # 2
mev347
It is very likely that the vehicle was overheating. gasket 15 20 tl for something to fit around that. oil decreases vehicle. if dripping too much, replace it
08.05.2020 17:09 # 3
black_rock
OK thanks
08.05.2020 17:09 # 4
muro_60
Replace the gasket.It will be a bad image for the engine.
08.05.2020 17:09 # 5
black_rock
Does fat decrease continuously?
08.05.2020 17:09 # 6
mev347
Is it running too much or less leakage
08.05.2020 17:09 # 7
black_rock
leak is low
08.05.2020 17:09 # 8
Bugra
friends said the solution, but if the car is above the limit, it may be by bleeding the gasket. First of all, check the oil level. but it is useful to change the gasket necessarily.
08.05.2020 17:09 # 9
black_rock
According to what you say the gasket needs to change ..
