Hello.I am working in Peugeot service ..
08.05.2020 14:16 # 1
erkan samur
friends I work in peugeot service, my goal is to help you . eminönal 2010-06-07 00:17:14
08.05.2020 14:16 # 2
EminONAL
Our members who have completed their new membership and entered the forum, please introduce yourself by opening a new topic under the heading "Let's Know Our Members ". Filling in all the information will help us to know you better.
1.- Your name and surname:
2.- Your age:
3.- Your vehicle (Brand, model):
4.- Your hobbies:
5.- Your profession:
6.- Where did you hear the site:
7.- Your Blood Group:
8.- Your horoscope:
9.- The team you support:
10.- Which county or province are you in:
11.- Your MSN address:
Thank you for your attention.
Peugeot Turkey Fun Club Management
Www.peugeotturkey.co & www.peugeotturkiye.co I
edit: subject is edited, linked messages are deleted.
08.05.2020 14:16 # 3
erkan samur
for sure bro thank you for correction
08.05.2020 14:16 # 4
rifatseker
Erkan Bey,
So let me get first aid, how much does 206 Plus 1.4 diesel charge for the first 10,000 maintenance and what maintenance does Peugeot Services :) Let's have a sword according to it. :)
08.05.2020 14:16 # 5
BAHTIYAR
welcome forums I want to ask a question immediately 307 automatic car service gearbox oil change is not necessary said the car 67 thousand km never changed unchanged oil in most familiar masters says what do you think I should do
08.05.2020 14:16 # 6
mabolla
Welcome brother, I have a question, I would be glad if you answer. 307 min overheating gave a warning like "engine temperature is too high". I'm glad.
08.05.2020 14:16 # 7
t@lip
Welcome Erkan Kardeş, pleasant forums ..
08.05.2020 14:16 # 8
welcome to us
08.05.2020 14:16 # 9
acad
Welcome my friend, we would be glad if you give information about where you are working in which service ..
08.05.2020 14:16 # 10
ACHTUNG
which one do you work
my çangada
text self-chief
I am sitting in Balıkesir, I asked him
08.05.2020 14:16 # 11
ankaramsnm
vehicle 1.4 gasoline 1999 partner problem that one month ago, the engine sealed master gasket burned said that when the engine was disassembled it said that it should change its pistons and liners, it was okay I said okey circlips pistons gasket etc. changed, so the engine was overhauled when the industry left the vehicle, abnormalities started in the vehicle, the vehicle was idle in both gasoline and gas started working wavy working cycle slowing accelerating did not keep any sort of order I went to the master again, said the problem in the carburetor, the complete carburetor has been overhauled, the result was not again from the same carburetor, then I went to arrange a computerized gas, they said to me elsewhere this vehicle is getting air from somewhere, it is said that it is working irregularly, but it is said that they couldn't find the place, the veteran, the morcuer, the biker, the carburetor, and the ball stopped and I was using it in this way, personally, my wing either tripped over the trigel cents or it was getting air from somewhere, but where did the car fall down on the vehicle norm At times, while doing 150 km, now 120 is going to be difficult. Would you recommend a good master in Ankara. Where could the malfunction be? Best regards
08.05.2020 14:16 # 12
Kemal
you wrote the wrong place first. Have you tried the same malfunction in gasoline or not just lpg?
08.05.2020 14:16 # 13
SahinGun
Erkan, welcome nurse ... What service are you in Balıkesirde?
08.05.2020 14:16 # 14
Long Beach
[QUOTE = ankaramsnm] vehicle 1.4 gasoline 1999 partner problem said that 1 month ago, the engine seal burned master gasket burned said that when the engine was disassembled, it should be changed in the pistons and liners, I said okey in the circumference piston pistons etc. it started working irregularly in both gasoline and gas, it runs wavy, the speed is decreasing, it did not keep it in order. I went to the master again. It was said, but they couldn't find a place that took the air, the veteran morcu threw the ball to the carburetor, the motorbike, and I was using it in this way. Ende fell in the normal times even 150 km while now 120 is going hard. Can you recommend a good master in Ankara. best regards [/ QUOTE]
Greetings,
First, are you sure the partner is also a carburetor?
Your guess is correct, they're wearing the wrong back.
Take it to a humane master-service who loves your job and get it done.
Problems that aren't even when the gasket is on start when repair comes out.
Do not deal with such masters. The master who takes the key to his hand becomes the master.
also; read the article below
Long beach 2010-06-10 12:24:12
08.05.2020 14:16 # 15
AydinBeyol
welcome pleasant forums
08.05.2020 14:16 # 16
erkan samur
an average of 200 250 TL, 10000 maintenance. diesel 15000 petrol, 20000 km maintenance, all filters are in oil as changing
08.05.2020 14:16 # 17
erkan samur
If you do not have a situation that will cause trouble for your use, if there is no malfunction, your vehicle has an al4 transmission. There is no oil change period in these wraps, and if the oil change is changed by an unknowing person, your expenses will increase.
08.05.2020 14:16 # 18
erkan samur
The green socket replaces the temperature sensor and the problem is solved in a guaranteed way.
08.05.2020 14:16 # 19
erkan samur
in çangas
08.05.2020 14:16 # 20
erkan samur
Are you sure the car is also a carburetor
Page : / 2
