Hello friends
08.05.2020 20:13 # 1
SNLYS
My vehicle 2006 model 407 1.6 hdi comfort km is about 164 thousand. I am generally satisfied with my vehicle. started to stop intermittently in the last 1 month, it can be restarted within 1-2 minutes, there is neither a decrease in power, nor an abnormality in fuel (such as burning, etc.). as if someone else giving the error message ...
Connected to the computer in the private service, we saw the error codes p0087 and p0093 each time.
briefly errors related to pump pressure. I was finally directed to the pumper
In the first place, I was told to replace the diesel filter and ramp sensor, if it does not improve, then I was told that a problem should be sought in the pump .. parts were replaced ..
result: the same fault continues and I went to the pump again, injectors were checked by the way .. the pump repair decision came out. ..
these days, the pump changed, I tested about 40-50 km, I used high speed, I used low speed, there was no problem and I came home happily.
I had to use the vehicle in the evening and I hadn't even gone for 5 km, which stopped again, the same error on the screen ...
for what reason there is such a problem .. thank you in advance
08.05.2020 20:13 # 2
First of all, welcome to us. I think the teacher takes the air from one place and don't forget to take back your pump to the fuel system. injector washers etc. I was checked. sonerkyl 2017-03-02 08:53:59
08.05.2020 20:13 # 3
GokhaN
I think if the pump has changed in the pump, I think the pressure of the injectors will be checked, since the vehicle is more than km, there is a high probability of injectors.
08.05.2020 20:13 # 4
SNLYS
[QUOTE = sonerkyl] first of all welcome to us. I think the teacher takes the air from one place and do not forget to take back your pump to the fuel system. injector washers etc. I was checked. [/ QUOTE]
[QUOTE = GökhaN] welcome I think if the pump has changed, check the pressure of the injectors because the vehicle is more than km, there is a high probability of injectors in the injectors [/ QUOTE]
nice friends, thank you also for your interest ...
Gokhan injectors have no problem, I had it checked before replacing the pump.
While researching this problem, someone was telling a similar situation in another forum, someone seemed to describe the same problem, stopping on the move and working normally as if there was nothing back then ... he wrote that the in-engine fuse box was replaced and the problem was resolved. As a reason, he wrote that there is no fault detection mechanism that checks the malfunctions in this fuse box, if there is a problem, he gives an error message, etc. but he did not write what error codes he saw.
I asked the master about it, and he said it was also possible, but when he connected it to the computer, he did not suspect the fuse box because he did not see any short circuit or electrical failure.
when i reach a solution i will share with you here
08.05.2020 20:13 # 5
kadirbap
don't worry, the problem is getting air in the fuel pipes or it should not be folded in vain
