Heavy maintenance cost
08.05.2020 17:58 # 1
mrtydnn
Good day has finally started to pull the flag of bankruptcy on my vehicle, which I could not maintain for a long time, I want to have some money in hand. But frankly, I do not quite understand the market of these works.
I showed it to a private service the other day, after a good review, we made a list together. Is it reasonable to want to know your opinion about the parts to change and their costs. My vehicle is 2004 model 206.
Right swing - 100 TL
Left swing - 100 TL
2 bend rods - 50 TL
2 bending tires - 60 TL
Right wheel bearing front - 120 TL
Left wheel bearing front - 120 TL
Right wheel bearing rear - 100 TL
Left wheel bearing rear - 100 TL
Engine ear bottom - 40 TL
Engine ear top right - 60 TL
Manifold oring (4 pieces) - 50 TL
Rocker cover gasket - 35 TL
2 vacuum organs - 25 TL
Front grank felt - 30 TL
Eccentric seal - 25 TL
4 injector washers - 10 TL
Heat shield (top + front + rear) - 180 TL
Clutch wire 75 TL
Air Filter - 20 TL
Oil filter - 15 TL
Diesel filter - 80 TL
Engine oil (4lt) - 65 TL
Pollen filter - 15 TL
Axle bearing - 30 TL
2 lt gearbox oil - 35 TL
Right axle felt - 15 TL
Left axle felt - 15 TL
Timing kit - 240 TL
Recirculation - 100 TL
3 lt antifreeze - 45 TL
6 lt pure water - 50 TL
3 sprays - 30 TL
Total spare parts cost - 2065 TL
Turner - 80 TL
Mechanical - 900 TL
Cleaning - 30 TL
Thanks in advance for enlightening you with your thoughts.
08.05.2020 17:58 # 2
pusutr
Hullo. I think the numbers have fallen out of the bag.
08.05.2020 17:58 # 3
Serkan
Unfortunately, get away from the prices, let me give you a few price examples, you will get the rest from the peugeot market.
Original timing set 152 TL
Original filter set 4 in one 100 TL
Original circulation 75 TL
Swing right-left pair 120 TL
You send the list to Şahin peugeot, get a price from there, your service written in abundance.
Serkan 2013-09-28 14:00:45
08.05.2020 17:58 # 4
mami202
If the timing set is 240 pounds with circulation, there is 15 pounds difference again.
the price of wheel bearings is fixed, the same oil air filters are everywhere, normal prices
mechanical workmanship fee seemed more than 900 pounds to me?
08.05.2020 17:58 # 5
206 ersan
God bless you, what a generosity.
08.05.2020 17:58 # 6
bordo_blue
The prices have been exaggerated. Well, if anyone knows about this, where can we get this kind of process in Ankara, can I inform it without distraction?
08.05.2020 17:58 # 7
kuscu38
the prices are cold, it didn't make sense to me ... I do not know you have gone my service but I think you can find a good engine master, list what needs to be changed, or if you go into maintenance, this is not heavy maintenance, it is the vehicle change you know. LOL
08.05.2020 17:58 # 8
mrtydnn
[QUOTE = kuscu38] my price teacher did not make sense to me ... I know you have gone my service but I think you find a good engine master, list what needs to be changed or if you go into maintenance, this is not a heavy maintenance but a vehicle change you know. LOL [/ QUOTE]
No, I did not go to the service, I was constantly looking for a new master as the master I took away retired a year ago, recently I went to a place I had my mind when the clutch wire failed and we took care of the random wire. We need to research three or five more places and find a reliable place.
08.05.2020 17:58 # 9
mrtydnn
[QUOTE = 206 ersan] thank you, goodbye use this generosity [/ QUOTE]
Do not ask, I'm scattering, I can't finish :)
08.05.2020 17:58 # 10
mrtydnn
Thank you friends, as far as I understand clearly that the people in the service I am visiting have disturbed the intent, is there a place in Izmir that you can recommend for such a care?
08.05.2020 17:58 # 11
samet206
I think that these prices can be found for better prices, if the prices are salty ...
08.05.2020 17:58 # 12
mrtydnn
[QUOTE = samet206] I think these prices can be found for better prices if the prices are salty ...
I haven't done any solid research yet, but the car is rebelling now, I said I'll show it somewhere to do maintenance, okay, we entered randomly.
I understand the size of the work, thanks to those who know it is good to consult. Clap
08.05.2020 17:58 # 13
samet206
[QUOTE = mrtydnn] [QUOTE = samet206] I think that these prices can be found for better prices, if the prices are salty ...
It is true that such things happen by experience and consultancy. You have written TL, but I paid 320 TL including swings on the swings, right and left. We are antifreeze. The prices of the same oil air maintenance filters have almost the same air filter for 15 TL.
08.05.2020 17:58 # 14
mrtydnn
[QUOTE = samet206]
I think they wrote the parts that are fixed in the market or they are sure, but they could not be sure or they wrote the pieces with unknown market price three or five more. With the list at hand, I can also try to get a bulk price from spare parts. In any case, it is necessary to take a few days and sift it.
It's not a problem to find a master who does his job well.
