Heavy maintenance
08.05.2020 19:35 # 1
ozgorh
Hello friends 206 is my first vehicle and heavy maintenance will be done and the caliper pad leaks water back wheel ball will change timing set oil maintenance needs to be done. Is there a quality and affordable service you can recommend in Istanbul.
08.05.2020 19:35 # 2
red 206
When I was buying the car, the engine had burned the gasket, the oil cooler heater was broken, the place where the car broke down, the uncle was the mechanic himself, especially the mechanic was not his own place. I'd be helpful if you want to see you.
