heating radiator
08.05.2020 15:40 # 1
kaderim@61
friends is it imperative to remove the chest to replace the radiator radiator, there is another way, respectfully if you inform. Thanks in advance for the answers; Koliva 2011-06-22 11:09:35
08.05.2020 15:40 # 2
kaderim@61
actual
08.05.2020 15:40 # 3
Yes unfortunately it is necessary.
08.05.2020 15:40 # 4
semih
my vehicle can change without removing the breast of 206 vehicles but i do not know about 106 s.
08.05.2020 15:40 # 5
kaderim@61
If I was not dismantled, I was going to put my big breast for a little piece of it.
08.05.2020 15:40 # 6
[QUOTE = my destiny @ 61] is not being removed without dismantling.
In some vehicles it can be in the proper place, in this case there is no need to insert a torpedo. But some vehicles have to be torpedo since they are in the interior. There is no other way...
08.05.2020 15:40 # 7
___KxL___
Only the middle part you call the big chest is removed, the air conditioner is where you turn on the heater and the center console is removed.It is impossible to install without dismantling.
08.05.2020 15:40 # 8
kaderim@61
I hope so, I asked most people to be inserted, said to whom we said, we will change the hurry forward, they said something:
08.05.2020 15:40 # 9
toprakk
REMOVING THE CHEST IS NOT TO DAMAGE THE HONEYS WHEN INSTALLING THE RADIATOR. REMOVING TO MAKE IT EASY IN THE MOTORAGE. It can be worn without dismantling, but since there is a very blind spot in ALLT, it does not matter, and the combs are very weary. VERY BLIND AT THE POINT FOR THE CONNECTION.
08.05.2020 15:40 # 10
Let me ask a little off topic; What is the solution for broken chest nails? The right part of the chest of my vehicle shakes loudly. I will have my chest removed and made, but I do not have my fear that they will hurt other places.
[QUOTE = CeCoLi] [QUOTE = my destiny @ 61] is not being removed without dismantling.
08.05.2020 15:40 # 11
kaderim@61
I asked a master, I said, I will wear it without inserting it. How did I look at me?
08.05.2020 15:40 # 12
kaderim@61
due to unintentional sounds Sırıtma
08.05.2020 15:40 # 13
kaderim@61
friends, I changed the radiator radiator without removing the chest, cut the radiator's pipes and made the connection from inside. so there was no need to remove the chest. respectfully, I was going to throw your pictures into your information, but I couldn't understand uploading pictures.
08.05.2020 15:40 # 14
denizcAn
by_polat 2011-07-01 14:11:28
08.05.2020 15:40 # 15
[QUOTE = my destiny @ 61] friends changed the radiator radiator without disconnecting the chest, cut the radiator's pipes and made the connection. so there was no need to remove the chest. With my best regards, I was going to throw your pictures into your information, but I couldn't understand uploading pictures if you helped. [/ QUOTE]
You upload the pictures somewhere and write them here. We are regulars.
Get well soon.
