heating aid
08.05.2020 16:32 # 1
42life
2 in my car I run the car is warming up, but I bring the heating to the full speed, although it does not give it hot even though it warms, it may cause lpg mounted & nbsp;
08.05.2020 16:32 # 2
peugeotefe
Have the heater hoses checked maybe they have canceled there is no hot air circulation inside if there is no entry or exit to the heater radiator
08.05.2020 16:32 # 3
42life
thank you but it gives hot. how to say fan 4-stage or 3-stage vehicle as hot heater heat as if it is given with cold. no air conditioner in the vehicle & nbsp;
08.05.2020 16:32 # 4
peugeotefe
Heating radiator may be clogged, teacher or heating boiler, there is a problem.
08.05.2020 16:32 # 5
42life
What should I do? I guess it's not an easy thing I can do. At least I think you found the problem. something easy to do? thanks again for your help
08.05.2020 16:32 # 6
djchaos
Show to a master in the vehicle industry If the heating problem is not something you can do, you can get help from the sponsor of the site if there is a part problem
AUTO EFE
Peugeot & amp; Citroen
Exit Spare Parts
0212 486 33 66
www.peugeotcikmacisi.com
www.cikma-parcaci .com
08.05.2020 16:32 # 7
peugeotefe
If you take your car to a mechanic who understands the job, it can help you better, because the torpedo needs to be removed in order to do what I say.
08.05.2020 16:32 # 8
42life
hm yes it is not a problem i can do by myself.
08.05.2020 16:32 # 9
caglargungor
chest & nbsp; There is no need to disassemble it. There is a separate device, you can connect it to the heating hoses and clean them. Try that method.
