Heater Radiator Replacement Time
08.05.2020 15:00 # 1
eneslan
Hello friends, my 2006 model 307 vehicle is 64 thousand and the other day I ordered parts to replace the radiator. Why and How?
First of all, there was a smell in my car and it was not past for days. I applied an air conditioner cleaner and the smell was cut, but at the same time I had a newspaper under my rubber mats because the floor carpets were wet in the Washer.
My newspaper and mop were not soaked, even after a week. I was in the service by chance and asked. They examined them and the leak appeared in the central heating radiator, and this part was giving water drop-in to the interior where it changed from the inside of the car.
In this respect, we observed a large decrease in the engine water level of my vehicle. As I said, my car is a 2006 model in 64 thousand. I will replace the part that is about 300 TL. Except for this piece workmanship. The reason for the change is that it deforms over time, etc., and so on.
You guys keep in mind.
08.05.2020 15:00 # 2
4 years ago I'm over pity pejo, then a friend duh
08.05.2020 15:00 # 3
I agree exactly with lanope. 95 model lada samaram's calorie heat is still intact :)))
but this situation may not be considered for all pugs. I guess it should be a bit of chance in such cases. But if the water is squirting, it doesn't have the same quality ...
08.05.2020 15:00 # 4
erdal
Well, my car is 10 years old, but I did not have such a problem.
08.05.2020 15:00 # 5
Oh God bless. Torpedo is inserted in many vehicles rather than money.
08.05.2020 15:00 # 6
eneslan
Well maybe a little bit of luck or it was really 4.5 years ago I don't know anymore =) for whatever reason
08.05.2020 15:00 # 7
peugeotefe
If you have used antifreeze for a long time and put antifreeze suddenly, the problem may be due to it.
08.05.2020 15:00 # 8
whatever is in the old cem new and complex whatever problem
08.05.2020 15:00 # 9
eneslan
[QUOTE = peugeotefe] If you have used antifreeze for a long time and put it on antifreeze, the problem may be due to it. [/ QUOTE]
Well, no antifreeze had changed. So the possibility of this occlusion, etc., only antifreeze causes it? what is the root problem?
08.05.2020 15:00 # 10
Psh
I had this problem at 160,000. But I was kidnapping not the radiator but the gasket of the radiator. We changed the gasket to 5 liras, the problem is over.
