HEATER MOVEMENT
08.05.2020 15:24 # 1
sukur
Sa friends. This is the first time I have traveled long with my vehicle. some problems arose. Most importantly, it started not heating heating. Also, for the first time when the vehicle accelerated, I saw that the temperature fell to zero ... I do not know if there are two interconnected problems, but it is as if both started at the same time. Let me state this. Heat comes to the pipes under the torpedo. it feels good, but this is not reflected in the heating system.
08.05.2020 15:24 # 2
Since the heating core is clogged, the temperature decreases, and even it does not heat, I recently had the replacement of the honeycomb. I have no exact idea of overheating. You can get more accurate results if you specify what your tool is. good forums.
08.05.2020 15:24 # 3
sukur
106 xs 1998 model master. It made me so cold :) I drove the car with the blanket yaw truckers laughed
08.05.2020 15:24 # 4
metin
I say it may be from the thermostat but if the cem is angry I will not interfere (
You said that it does not heat on the long road, in my opinion, because the thermostat remains open, the incoming wind absorbs the water and the cold water enters the engine and takes off the heat of the engine because the circulation works. Since the temperature is low, the heater cannot heat, and by the way, the engine cannot heat up since cold water enters the engine from the radiator and the temperature is low.
text 2011-05-10 17:25:33
08.05.2020 15:24 # 5
[QUOTE = text]
I agree +1 Alkış
08.05.2020 15:24 # 6
metin
[QUOTE = cecol of] [QUOTE = text]
I agree +1 Alkış
StarStarStar
this time the correct diagnosis (:
08.05.2020 15:24 # 7
mdincer34
I had been in the previous vehicle, the thermostat looks at it, it makes malfunctions first, sometimes I am so cold then it changed in the thermos, like a hama :) it is not healthy to work with cold water.
08.05.2020 15:24 # 8
ose
Since the thermostat does not heat the water, it cannot supply hot water to the honeycomb, and I agree, but it is thought-provoking that heat comes to the pipes under the torbidone.
08.05.2020 15:24 # 9
metin
[QUOTE = kankam_743] the thermostat cannot supply hot water to the honeycomb because the water is not heated, but I agree, but it is suggestive that heat comes to the pipes under the torbidone. [/ QUOTE]
the pipes are coming to the pipes, but because it is about 20-30 degrees, the friend feels like the pipes are hot, also, since the indicator does not show below 60 degrees, the friend must have thought that the temperature was down to zero.
08.05.2020 15:24 # 10
ALX
I agree with our text friend, the thermostat will be replaced or installed. Electricians cut my thermostat, there was no problem in the summer, but the heat would drop a lot on the straight road in the winter. The car could not get hot. I got a thermostat, it got better.
08.05.2020 15:24 # 11
metin
[QUOTE = ALX] I agree with our text friend, the thermostat will be changed or installed. Electricians cut my thermostat, there was no problem in the summer, but the heat would drop a lot on the straight road in the winter. The car could not get hot. I got a thermostat, it got better. [/ QUOTE]
how is this mindset? what head are they dismantling, what are the people working under the name of "master"
08.05.2020 15:24 # 12
flash296
Generally, the thermostat of the overheating vehicles is dismantled. ! be careful, if there is no thermostat, the vehicle is probably inflating, they removed it from it ... be careful before installing the thermostat !! because if it inflates after installing the thermostat, unfortunately it will burst the water supply or possibly the radiator!
08.05.2020 15:24 # 13
tigerland
Could you check if the radiator water is missing?
08.05.2020 15:24 # 14
goktug
buy heating cleaner sprays and see if it works
