heater lights
08.05.2020 20:49 # 1
Gboz3510
Hello, I just bought my car 308 1.6 VTI when I turn on the night lights of the heater, the lighting of the heating buttons does not work, but other lighting works, does anyone know what could be the reason? One has a multimedia tape attached to the vehicle, but when the contact is opened, it does not open on its own and when it is closed, it does not close itself. Confused
08.05.2020 20:49 # 2
M.Ahmet059
[QUOTE = Gboz3510] Hello, I just bought my car 308 1.6 VTI when I turn on the night lights of the vehicle, the lighting of the heating buttons does not work, but does anybody know what the reason is? One has a multimedia tape attached to the vehicle, but when the contact is opened, it does not open on its own and when it is closed, it does not close itself. Confused [/ QUOTE]
tape closing is happening with 1 cable or changing its location go to a place that makes a sound system they handle it in 2 minutes they don't even want money
08.05.2020 20:49 # 3
Gboz3510
Okay master, let me get a nice thing that the tape on it was not so stiff. But the lights on the heating buttons do not light up. It is difficult to use at night.
08.05.2020 20:49 # 4
Cheto43
I had a membership, I could not renew the password again, I became a member.
08.05.2020 20:49 # 5
GokhaN
I did not pay any attention to me, there were 3008 in my mind, there were 308 in the past.
08.05.2020 20:49 # 6
GokhaN
[QUOTE = Cheto43] I had a membership, I could not renew the password again, I became a member, teacher, I have pejo 307. [/ QUOTE]
E-mail your member name to info@peugeotturkey.com.
Gokhan 2018-04-05 16:01:08
08.05.2020 20:49 # 7
light bulbs are burst, teacher, it's easy to change the lamps if you have a little bit of this type of work.
08.05.2020 20:49 # 8
ORhun53
Sir, first of all, because it is not original, it can not use the steering control automatically. It can be used to switch on and off. If you want to investigate it, it is possible that the lights do not burn. The bulbs in it have exploded and you can easily disassemble it.
08.05.2020 20:49 # 9
Gboz3510
yes friends, thanks for the comments, i'm getting a compatible double on my car at the weekend, but is there any advice on that, because the models that are directly compatible with the car are 1.400 TL, I am going to buy a frame and install something of 600-700 TL
08.05.2020 20:49 # 10
pusutr
Installing a compatible screen makes more sense. It would be super if you plug in models with a rear view camera. You can use the buttons on the steering wheel, access the vehicle configuration via the tape. If it is not compatible with the vehicle, each battery will be removed from the terminal and the time, date, etc. You go to the service for the setting. I am sure they will get 50 TL each time. It's an effort when you lose it.
