HEATER ISSUE
08.05.2020 21:23 # 1
KETE
With my 2015 model peugeot bipper vehicle, the engine temperature does not rise until I come home from work. It stays at around 50-60 degrees. What I do is 7-8 kmm normal for these vehicles. KETE 2019-12-04 09:52:41
08.05.2020 21:23 # 2
First of all, welcome to us.Normal coach diesel vehicles get hot in the winter, unfortunately, and when the distance you go is short when the engine starts to warm up, you stop the vehicle. Of course, have your thermostat checked, my teacher may be due to him.
08.05.2020 21:23 # 3
KETE
teşekürler
08.05.2020 21:23 # 4
omerb
I think it's like normal. When I drive my Ford courier, it reaches 40-50 degrees after 4-5 km. If the same problem is 20-30 km on the long road try, the thermostat may also be a problem. You drive 7-8 km, but the speed you use here is also important, if you go at low speed, the engine will warm up later.
Good luck with.
