Heater is blowing cold air!
08.05.2020 16:16 # 1
phoenix.1905
Friends, my car does not blow hot air in the cold weather that is taking place in Istanbul right now. When I first start the car, I wait for a few minutes and then continue for 10-15 minutes without stopping for the engine to warm up. However, the blown air does not heat up. I just stepped on the gas in the form of 4000-4500 revolutions recently, it got a little warm. So wouldn't this car get hot while driving normally? Reviews
08.05.2020 16:16 # 2
Muhammet CAKIR
I need to warm up. Normally the same thing happened to me yesterday. I started the car. I warmed the car for 5 minutes or so. & Nbsp; It did not get hot until 7 km or so. The car warmed up a little something. We have to do winter maintenance. I think the antifreeze is low.
08.05.2020 16:16 # 3
I Love My Pug
It has to warm up normally, of course, when the temperature is low, it blows cold air, but it is not normal if it still blows cold even after the temperature rises. There may be a problem in the thermostat or in the circulation, winter is approaching, I think, look at it as soon as possible. 15:00
08.05.2020 16:16 # 4
Muhammet CAKIR
[QUOTE = I Love My Pug]. There may be a problem with the thermostat, winter is approaching, I think, look at it as soon as possible. "18" width = "18" border = "0" alt = "Grin" title = "Grin" /> & nbsp; If the temperature is high, the temperature does not rise in the future. I left it there when I came back home until I came home again, the temperature was better when I entered the same house, but it was cold on the roads: D
08.05.2020 16:16 # 5
I Love My Pug
[QUOTE = Muhammet ÇAKIR] [QUOTE = I Love My Pug]
It has to warm up normally, of course, when the temperature is low, it blows cold air, but if it still blows cold even after the temperature rises, this is not normal. . There may be a problem with the thermostat, winter is approaching, I think, look at it as soon as possible. "18" width = "18" border = "0" alt = "Grin" title = "Grin" /> & nbsp; If the temperature is high, the temperature does not increase in the future, I can say that the temperature has gone back to normal when stopping the car in vain: D but car I left it there when I came back home, the temperature was better when I entered the same house until I came home, but on the roads cold: D [/ QUOTE]
& nbsp;
:)) then I can't say anything, my brother wear a thick top, & nbsp; wool underwear and stuff :) )
08.05.2020 16:16 # 6
Muhammet CAKIR
[QUOTE = I Love My Pug] [QUOTE = Muhammet ÇAKIR] [QUOTE = I Love My Pug]
It has to warm up normally, of course, when the temperature is low, it blows cold air but the temperature rises this is not normal if it still blows cold even afterwards. There may be a problem with the thermostat, winter is approaching, I think, look at it as soon as possible.
[/ QUOTE] "Grin" & nbsp; If the temperature is high, the temperature does not rise in the future. I left it there when I got back, the temperature was better when I entered the same house until I came home, but it was cold on the roads: D [/ QUOTE]
& nbsp;
[/ QUOTE] "Grin" "Grin" & nbsp; I have dressed my brother, thank you & nbsp; I think we're going to do it between the cities first to warm up. how beautiful it was: D
08.05.2020 16:16 # 7
Let me try it in the morning and see if it works.
08.05.2020 16:16 # 8
phoenix.1905
I drove to normal temperature & nbsp; already. It was 90C cold. I pushed a little bit, the beehive rose to 100C, but it still blew cold. Could the antifreeze be minimal, have anything to do with it?
08.05.2020 16:16 # 9
Muhammet CAKIR
[QUOTE = phoenix.1905] I drove to normal temperature & nbsp; already. It was 90C cold. I pushed a little bit, the beehive rose to 100C, but it still blew cold. Could the antifreeze be minimal, have anything to do with it? [/ QUOTE] The temperature should normally stop at 90, although the temperature is normal in peugeot, but the chlorine of the heater is not normal.
08.05.2020 16:16 # 10
phoenix.1905
When there should be adjustments on the front panel. set on the hot part.
08.05.2020 16:16 # 11
Haksen016
the thermostat may be faulty, the engine will remain cold if it is open or missed. Increases in fuel.
08.05.2020 16:16 # 12
efsanemurat
friends, the temperature is always low and barely ramps when it reaches 90. Normal time always stays at 70 and 80. It never goes up to 90. At first, my car warmed up would be 90 immediately. Even the ramps would be 100.
08.05.2020 16:16 # 13
I Love My Pug
It may be from the thermostat and the circulation pump, brother, take a look at them, I do not think it will give cold air since it is not antifreeze, because the antifreeze is placed to prevent the water from freezing.
08.05.2020 16:16 # 14
I Love My Pug
[QUOTE = legendary] My temperature is always at 70 and 80 when I force it on low ramps, it reaches 90 in normal time, it always stays at 70 and 80. / QUOTE]
& nbsp;
My brother & nbsp; I think your problem is about the heat sensor.
I Love My Pug 2011-10-18 20:46:37
08.05.2020 16:16 # 15
[QUOTE = Muhammet ÇAKIR] [QUOTE = phoenix.1905] I drove to normal temperature & nbsp; already. It was 90C cold. I pushed a little bit, the beehive rose to 100C, but it still blew cold. Could the antifreeze be minimal, have anything to do with it? [/ QUOTE] the temperature should normally stop at 90, but it is normal in peugeot but the chlorine of the calorie is not normal, it is normal in the calorie settings, is it cold or maybe [/ QUOTE]
french people are cold or cold maybe
08.05.2020 16:16 # 16
zavur
I guess you can't see it 100 degrees easily, or rather I couldn't see it. Your vehicle did not turn on, so it should not be out after a maximum of 90 minutes. & Nbsp; & nbsp;
08.05.2020 16:16 # 17
zavur
When I was going to 180, I looked at it was 75 degrees and I stayed open & nbsp; "Smirk" "Grin"
08.05.2020 16:16 # 18
OkaN
brother your honeycombs might be clogged & nbsp;
08.05.2020 16:16 # 19
Platinium
[QUOTE = phoenix.1905] Guys, my car is not blowing hot air during the cold weather in Istanbul right now. When I first start the car, I wait for a few minutes and then continue for 10-15 minutes without stopping for the engine to warm up. However, the blown air does not heat up. I just stepped on the gas in the form of 4000-4500 revolutions recently, it got a little warm. So wouldn't this car get hot while driving normally?
Very likely to be from the heater core & nbsp; it should be quite difficult to disassemble
I can say that my car is blowing at a temperature that cannot be rinsed in a short time
Platinium 2011-10-18 22:56:57 < / editdat a>
08.05.2020 16:16 # 20
hot cold tap might be stuck in the bed & nbsp;
Page : / 2
