Heater-air conditioner cold hot air transition problem
08.05.2020 21:12 # 1
sanlimen
Hello friends,
I want to remove the place where I put my photo on my 307 vehicle. There is a screw in the place I marked with a small circle, I can disassemble it, but I could not remove the parts to the left and right of it, I did not want to pull it by force, does anyone know how to do it?
As for why I want this;
there was an engine that provided hot-cold air exchange. turning the temperature knob over the heater, the knob here turns and the temperature is blown inside. filth accumulates in it and it cannot turn completely. Therefore, it cannot reach the coldest and hottest temperatures. When it clears a little, it can change to a cooler and warmer setting. but I couldn't remember how we disassembled it. I remember that we did not remove the gear knob, nor did we remove the screw inside the torpedo.
08.05.2020 21:12 # 2
ismailkaya
air conditioner digital or analog
while digital, motor gears are broken. Analogue thread is released.
08.05.2020 21:12 # 3
sanlimen
Manual air conditioning. Is it necessary to remove the glove box to remove the parts?
08.05.2020 21:12 # 4
I have to remove the part in the part where I have the handbrake to remove it completely.
08.05.2020 21:12 # 5
Orcun.Dmr
There are two T20 screws and one has a plastic clip on the motor side. After removing the screws and clip, it is easily removed. If the photo belongs to your vehicle, your air conditioner is digital. orçun.dm is 2019-04-02 11:46:04
08.05.2020 21:12 # 6
sanlimen
I found the photo from the ads. I unscrewed two screws, but since I couldn't find the clip, I pulled it back. I'll try again on weekdays. thanks.
