heated part
08.05.2020 17:03 # 1
foresteng.
Last I noticed, I noticed that the right headlight above the hood was getting too hot. When I open the hood, & nbsp; (marked in red) I think it's the brain. It gets very hot. The vehicle is automatic, AL4 .. There was no problem when I started the service last month. But the gear started to kick too late, sometimes 4500 rpm.
Anybody having such a problem or knowing why? & Nbsp;
I'm waiting for your comments ..
08.05.2020 17:03 # 2
soner09
WALLAHI HAVE NO KNOWLEDGE, MY SISTER IS SORRY IN AUTOMATIC
08.05.2020 17:03 # 3
How are these links? Does any hose come in? Or which units are they connected to?
08.05.2020 17:03 # 4
foresteng.
Well, every 206 parts is an electronic one. But I don't know why it gets hot ??
08.05.2020 17:03 # 5
It must be an ECU.
08.05.2020 17:03 # 6
feline
I guess it doesn't heat up but
08.05.2020 17:03 # 7
Sufibey
& Nbsp; & nbsp; Your driving style and the way you step on the road determine the gear changes. There is always a problem if the gear shifts at the top speeds.
08.05.2020 17:03 # 8
foresteng.
I know that according to my driving style, gear changes will be different. But chronically it detects when AL4 gets hot ..
I also noticed that the part I marked in red has just warmed up ... & nbsp;
When I connected the transmission to the computer in the service, it didn't give any error code ...
08.05.2020 17:03 # 9
xpyhre
[QUOTE = feline] bsi I guess it doesn't heat up, but [/ QUOTE]
bsi brain not in the 206s where the fuse panel is under the steering wheel?
08.05.2020 17:03 # 10
foresteng.
I guess nobody knows exactly what that piece is ...
08.05.2020 17:03 # 11
[QUOTE = foresteng.] I guess no one knows exactly what that piece is ... [/ QUOTE]
I said ECU or "C
Here is the number 1 part:
coli < / editID> 2012-09-27 10:47:42
08.05.2020 17:03 # 12
foresteng.
ok thank you .. But why does it get warm or why does it get too hot to feel from the hood? & nbsp;
08.05.2020 17:03 # 13
berk2309
close to the hood and if there is no insulation cap, I think naturally it is also natural in warming the temperature, and I think you are using a computer at home.
08.05.2020 17:03 # 14
foresteng.
The analogy is nice, but there was Maream before .. but it has never been warmed like this ...
The human is getting bored .. you are looking for a reason or not ... & nbsp;
08.05.2020 17:03 # 15
xpyhre
If your vehicle's ECU brain warms up so much, you will get a more relaxed and clear answer if you ask the authorized service. not to deal with it & nbsp; If something happens to the brain, it will not be easy to find and it is quite fluffy.
08.05.2020 17:03 # 16
foresteng.
[QUOTE = xpyhre] If your vehicle's ecu brain warms up to you, if you suspect it, you will get a more relaxed and clear answer if you ask the authorized service. not to deal with it & nbsp; If something happens to the brain, it will not be easy to find and it is quite fluffy. [/ QUOTE]
I was thinking the same thing, finally ..
