heat-fan
08.05.2020 14:13 # 1
Onur
The temperature of the 206 xr 2000 model car is traveling between 70-80, it only comes to 90 when I squeeze it on the ramp. It seems to me that it is not normal between 70-80.
08.05.2020 14:13 # 2
BuRCaK
I went to the weekend, master. said normal. He opens the fan at 97, said no problem. do not worry.
08.05.2020 14:13 # 3
hasimayaz
When going fast, it goes at low levels due to air flow. compression at low speed increases to 90-odd .. typical french.
08.05.2020 14:13 # 4
Onur
Even if the brother of 90 does not climb above 90, stop and get up, 70-80
08.05.2020 14:13 # 5
cerci07
Open the thermostat at 80, 90-100 fans are working on our vehicles
08.05.2020 14:13 # 6
b55can
It rises immediately when there are 80 fixed ramps on the straight road, 90 and 95-100 in congested traffic is very strange. then it is fixed at 90 and it never falls below 90 and it does not go above 6 years like that I could neither understand nor understand the reason for this volatility in the pejo.
08.05.2020 14:13 # 7
seLim
What awaits us in the summer, I am curiously waiting ..
08.05.2020 14:13 # 8
arifkemal
Honor may be a problem with one of the clients. Connect to a computer, there is a record if there is a problem. look and see if there is a new update of automatic transmission. 50 lira something you can see everything :)
