headlights illumination is insufficient
Homepage » PEUGEOT MODELS (FAULTS AND SOLUTIONS) » 406
08.05.2020 15:57 # 1
statistican
friends, my 406's right headlight is light yellow like dirty glass,
it does not light the way, what do you suggest me to do if I have a strong xenon, how much does it cost?
and is it also problem with xenon?
08.05.2020 15:57 # 2
It is not correct to install xenon lamps on original headlights because they are lensless. If you apply xenon in this way, you will create dangerous situations in traffic. There is a way to wipe your headlight only if the mosque is dirty. Just search in the forum will be enough.
08.05.2020 15:57 # 3
metin
Enter megiuarsin site I would recommend making the headlight lenses clean, which has a product called plastx.
If you are going to do it, it is very difficult by hand, but you can do it by attaching a cloth / sponge etc. to a drill etc. tip.
08.05.2020 15:57 # 4
dude both have that headlight clean and adjust the headlight. headlamps are below. There is a headlight adjustment machine in rot balancers. They make 50tl of shimmer in the eyeshadow. like on the xenon like ohh
08.05.2020 15:57 # 5
xenon undergoes inspection
08.05.2020 15:57 # 6
statistican
The headlight adjustment is done properly, let me clean it ... let's not know why it is dangerous without xenon lens ...
I am already lowering the city's inner lights.
08.05.2020 15:57 # 7
metin
[QUOTE = statistican] headlight adjustment is done properly, let me clean it ... let's not understand why xenon lenses are dangerous ...
xenon lights are not like halogens. Normally, the halogen bulb in the original headlight does not overflow the bowl inside the headlight, so it does not disturb anyone on the road.
If you apply xenon to the halogen, i.e. lens-free headlight, the light will be very diffuse because the headlight is halogen when it burns. only the road will illuminate the mountain, whatever the stone will illuminate everywhere. therefore, the line of cut is not certain, as the eye of the oncoming person is not clear, so it is not done in the setting.
If the headlight had a lens, when it wears a xenon, the lens collects together because it prevents the light from scattering, thanks to the curtain inside, it only illuminates the front, and does not take the eye of the oncoming, and the headlight adjustment is made very comfortable. Since the headlight adjustment is made, there is no problem in the examination because the adjustment is easily controlled.
08.05.2020 15:57 # 8
statistican
It does not have a lens, so ... then I clean it as much as the headlight illuminates.
08.05.2020 15:57 # 9
statistican
I searched on old subjects, sandpaper silicon polishing job was in my mind, if I use the porcöz to the main purpose, I wonder if I would use a small hole :)
