HEADLIGHTS ARE OPENED BY ITS HELP !!!
08.05.2020 15:08 # 1
fifietto
Hello friends,
Even though the headlights of my Peugeot 206 are off the arm, it lights up spontaneously, the signal flashes when it touches the lever, but after a while it does the same thing, also when the horn does not work, it touches the arm again and when the headlights go out, the horn starts to work, I did not understand what it is. Friends who will give an idea, please help .. Thanks in advance .. fifietto 2011-03-02 11:50:13
08.05.2020 15:08 # 2
masumserseri
There is a problem with the arm arm leg. It needs to change. You can find it in reasonable prices.
08.05.2020 15:08 # 3
Ozgur
com2000 is corrupted. (namely signal wiper arm set)
I hope repair is possible.
08.05.2020 15:08 # 4
klemann
Com2000 problem. the same is in my car.
08.05.2020 15:08 # 5
kingofsnipers
I have that same problem. In fact, when I first lived, I thought there was a headlight sensor in the car, it burned when it got into the dark because by chance :)
I talked to an electrician then he said that the winding should be changed, it was an easy operation, but I haven't stopped by for months :(
